[postgis-tickets] [PostGIS] #3601: Translation Backrolled
PostGIS trac at osgeo.org
Sat Jul 23 02:50:48 PDT 2016
  Reporter:  ruvyn          |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  high           |  Milestone:  PostGIS 2.3.0
 Component:  documentation  |    Version:  trunk
Resolution:                 |   Keywords:  PostGIS 2.3.0dev Manual
Comment (by ruvyn):
 Replying to [comment:2 strk]:
 > There is no trace in the repository showing _who_ pushed the 2015-09-29
 translations to Transifex, does Transifex known ?
 In Transifex, on History tab, you can see "by strk, 19 days ago". That was
 Mon, Jul 4 2016 2:29PM.
 See
 https://www.transifex.com/postgis/postgis/translate/#ko_KR/postgisxmlpot/19188018
 > I've committed the changes with r15023. Should we try contenting a
 smaller change, for test purpose ?
 Yes, I think you can test on postgis.xml.pot file, link above, cause it is
 the smallest - just 6 strings - file. I have a question though. I can see
 you committed my translation files to the server, but the translation
 texts are not applied on Korean Manual Webpage http://postgis.net/docs
 /manual-dev/postgis-ko_KR.html, could you please check out why?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3601#comment:3>
