[postgis-tickets] [PostGIS] #3496: Make postgis non-relocateable and schema qualify at least core functions
PostGIS trac at osgeo.org
Fri Jul 29 01:59:17 PDT 2016
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 I've noticed you simply stripped away the @extschema at .
 Would it make more sense to replace it with a configure-time decided
 schema instead ?
 That way you could still have a secure installation of PostGIS in your
 schema of choice.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3496#comment:6>
