[postgis-tickets] [PostGIS] #3471: Make install failed without complaining on linux
PostGIS trac at osgeo.org
Sun Jul 31 22:03:29 PDT 2016
  Reporter:  ehabets  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 2.3.0 => PostGIS 2.4.0
Comment:
 It's not needed if you compile from tar ball since the comments.sql files
 it builds are packaged as part of the tar ball.  Were you compiling from
 repo? If you were compiling from tar ball I'd consider it a more serious
 bug.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3471#comment:1>
