[postgis-tickets] r14936 - Correct ST_ClusterDBSCAN doc XML
Daniel Baston dbaston at gmail.com
Mon Jun 6 06:42:13 PDT 2016
Author: dbaston
Date: 2016-06-06 06:42:12 -0700 (Mon, 06 Jun 2016)
New Revision: 14936
   trunk/doc/reference_measure.xml
Modified: trunk/doc/reference_measure.xml
--- trunk/doc/reference_measure.xml	2016-06-06 12:28:13 UTC (rev 14935)
+++ trunk/doc/reference_measure.xml	2016-06-06 13:42:12 UTC (rev 14936)
@@ -1087,11 +1087,15 @@
 	  <para>
 		  An input geometry will be added to a cluster if it is either:
 		  <itemizedlist>
-			  <listitem>
-				  A "core" geometry, that is within <varname>eps</varname> distance of at least <varname>minpoints</varname> other input geometries, or
+              <listitem>
+                  <para>
+                      A "core" geometry, that is within <varname>eps</varname> distance of at least <varname>minpoints</varname> other input geometries, or
+                  </para>
 			  </listitem>
 			  <listitem>
-				  A "border" geometry, that is within <varname>eps</varname> distance of a core geometry.
+                  <para>
+                      A "border" geometry, that is within <varname>eps</varname> distance of a core geometry.
+                  </para>
 			  </listitem>
 		  </itemizedlist>
 		</para>
