[postgis-tickets] [PostGIS] #3573: Operator <<->> incorrectly calculates m distance
PostGIS trac at osgeo.org
Tue Jun 7 06:51:27 PDT 2016
  Reporter:  dbaston  |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.2.3
 Component:  postgis  |    Version:  2.2.x
Resolution:  fixed    |   Keywords:
Description changed by dbaston:
Old description:
> When computing the m-distance between a point and a line, the m ordinate
> of the point is ignored.
> SELECT 'POINT M (0 0 100000)'::geometry <<->> 'LINESTRING M (0 0 5, 0 1
> 6)'::geometry AS dist;
>  dist
>     5
> SELECT 'POINT M (0 0 1e9)'::geometry <<->> 'LINESTRING M (0 0 5, 0 1
>  dist
>     5
New description:
 When computing the m-distance between points and lines, the m ordinate of
 the first geometry is ignored.
  dist
     5
  dist
     5
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3573#comment:2>
