[postgis-tickets] [PostGIS] #3575: Error in Manual - ST_GeomFromEWKB (8.4. Geometry Constructors)
PostGIS trac at osgeo.org
Mon Jun 13 19:27:17 PDT 2016
 Reporter:  ruvyn                    |      Owner:  robe
     Type:  defect                   |     Status:  new
 Priority:  medium                   |  Milestone:  PostGIS 2.3.0
Component:  documentation            |    Version:  trunk
 Keywords:  PostGIS 2.3.0dev Manual  |
 String #74 of 'reference_constructor.xml.pot':
 "In PostgreSQL 9.1+ - standard_conforming_strings is set to on by default,
 where as in past versions it was set to on. You can change defaults as
 needed for a single query or at the database or server level. Below is how
 you would do it with standard_conforming_strings = on. In this case we
 escape the ' with standard ansi ', but slashes are not escaped"
 I am confused. Is standard_conforming_strings set to "on" or "off" in
 PostgreSQL 9.1+?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3575>
