[postgis-tickets] r14946 - style only change: remove trailing spaces
Sandro Santilli strk at kbt.io
Wed Jun 15 02:14:27 PDT 2016
Author: strk
Date: 2016-06-15 02:14:27 -0700 (Wed, 15 Jun 2016)
New Revision: 14946
   trunk/postgis/lwgeom_functions_basic.c
   trunk/postgis/postgis.sql.in
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c	2016-06-14 10:29:08 UTC (rev 14945)
+++ trunk/postgis/lwgeom_functions_basic.c	2016-06-15 09:14:27 UTC (rev 14946)
@@ -140,7 +140,7 @@
 	/* create a text obj to return */
 	mytext = cstring2text(result);
 	pfree(result);
 	PG_FREE_IF_COPY(geom,0);
 	PG_RETURN_TEXT_P(mytext);
@@ -176,7 +176,7 @@
 	char ver[32];
 	if ( rev > 0 )
-		snprintf(ver, 32, "%d", rev);
+		snprintf(ver, 32, "%d", rev);
 		PG_RETURN_TEXT_P(cstring2text(ver));
 	else
@@ -276,9 +276,9 @@
 	area = lwgeom_area(lwgeom);
-	lwgeom_free(lwgeom);
+	lwgeom_free(lwgeom);
 	PG_FREE_IF_COPY(geom, 0);
 	PG_RETURN_FLOAT8(area);
@@ -331,7 +331,7 @@
 	GSERIALIZED *geom = PG_GETARG_GSERIALIZED_P(0);
 	LWGEOM *lwgeom = lwgeom_from_gserialized(geom);
 	double perimeter = 0.0;
 	perimeter = lwgeom_perimeter(lwgeom);
 	PG_RETURN_FLOAT8(perimeter);
@@ -350,7 +350,7 @@
 	perimeter = lwgeom_perimeter_2d(lwgeom);
@@ -619,7 +619,7 @@
 	if (lwgeom_is_empty(point))
 		PG_RETURN_NULL();
 	result = geometry_serialize(point);
 	lwgeom_free(point);
 	lwgeom_free(lwgeom1);
@@ -646,9 +646,9 @@
 	error_if_srid_mismatch(lwgeom1->srid, lwgeom2->srid);
 	theline = lwgeom_closest_line(lwgeom1, lwgeom2);
 	if (lwgeom_is_empty(theline))
-		PG_RETURN_NULL();
+		PG_RETURN_NULL();
 	result = geometry_serialize(theline);
 	lwgeom_free(theline);
@@ -676,7 +676,7 @@
 	theline = lwgeom_furthest_line(lwgeom1, lwgeom2);
 		PG_RETURN_NULL();
@@ -710,11 +710,11 @@
 	PG_FREE_IF_COPY(geom1, 0);
 	PG_FREE_IF_COPY(geom2, 1);
 	/*if called with empty geometries the ingoing mindistance is untouched, and makes us return NULL*/
 	if (mindist<FLT_MAX)
 		PG_RETURN_FLOAT8(mindist);
 	PG_RETURN_NULL();
@@ -729,7 +729,7 @@
 	double mindist;
 	GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
 	GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
-	double tolerance = PG_GETARG_FLOAT8(2);
+	double tolerance = PG_GETARG_FLOAT8(2);
 	LWGEOM *lwgeom1 = lwgeom_from_gserialized(geom1);
 	LWGEOM *lwgeom2 = lwgeom_from_gserialized(geom2);
@@ -761,7 +761,7 @@
 	double maxdist;
@@ -772,16 +772,16 @@
 	maxdist = lwgeom_maxdistance2d_tolerance(lwgeom1, lwgeom2, tolerance);
 	/*If function is feed with empty geometries we should return false*/
 	if (maxdist>-1)
 		PG_RETURN_BOOL(tolerance >= maxdist);
 	PG_RETURN_BOOL(LW_FALSE);
@@ -803,11 +803,11 @@
 	if (maxdist>-1)
 		PG_RETURN_FLOAT8(maxdist);
 	PG_RETURN_NULL();
@@ -831,10 +831,10 @@
 	// point = lw_dist3d_distancepoint(lwgeom1, lwgeom2, lwgeom1->srid, DIST_MIN);
-		PG_RETURN_NULL();
+		PG_RETURN_NULL();
 	lwgeom_free(point);
 	lwgeom_free(lwgeom2);
@@ -861,12 +861,12 @@
 	theline = lwgeom_closest_line_3d(lwgeom1, lwgeom2);
 	// theline = lw_dist3d_distanceline(lwgeom1, lwgeom2, lwgeom1->srid, DIST_MIN);
 		PG_RETURN_NULL();
@@ -893,12 +893,12 @@
 	theline = lwgeom_furthest_line_3d(lwgeom1, lwgeom2);
 	// theline = lw_dist3d_distanceline(lwgeom1, lwgeom2, lwgeom1->srid, DIST_MAX);
 		PG_RETURN_NULL();
@@ -925,7 +925,7 @@
@@ -944,7 +944,7 @@
 	double mindist;
@@ -960,7 +960,7 @@
 	/*empty geometries cases should be right handled since return from underlying
 	 functions should be FLT_MAX which causes false as answer*/
 	PG_RETURN_BOOL(tolerance >= mindist);
@@ -977,7 +977,7 @@
 	double maxdist;
@@ -992,7 +992,7 @@
 	if (maxdist>-1)
@@ -1018,7 +1018,7 @@
 	if (maxdist>-1)
@@ -1133,7 +1133,7 @@
 	type1 = lwgeoms[0]->type;
 	type2 = lwgeoms[1]->type;
 	if ( (type1 == type2) && (!lwgeom_is_collection(lwgeoms[0])) )
 		outtype = lwtype_get_collectiontype(type1);
 	else
@@ -1212,12 +1212,12 @@
 	count = 0;
 	outtype = 0;
-#if POSTGIS_PGSQL_VERSION >= 95
+#if POSTGIS_PGSQL_VERSION >= 95
 	iterator = array_create_iterator(array, 0, NULL);
 #else
 	iterator = array_create_iterator(array, 0);
 #endif
 	while( array_iterate(iterator, &value, &isnull) )
 		GSERIALIZED *geom;
@@ -1226,7 +1226,7 @@
 		/* Don't do anything for NULL values */
 		if ( isnull )
 			continue;
 		geom = (GSERIALIZED *)DatumGetPointer(value);
 		intype = gserialized_get_type(geom);
@@ -1284,8 +1284,8 @@
 	array_free_iterator(iterator);
 	POSTGIS_DEBUGF(3, "LWGEOM_collect_garray: outtype = %d", outtype);
 	/* If we have been passed a complete set of NULLs then return NULL */
@@ -1359,7 +1359,7 @@
 	LWGEOM *outlwg;
 	uint32 ngeoms;
 	int srid = SRID_UNKNOWN;
 	ArrayIterator iterator;
 	Datum value;
 	bool isnull;
@@ -1393,7 +1393,7 @@
 	geoms = palloc(sizeof(LWGEOM *) * nelems);
 	ngeoms = 0;
 #else
@@ -1405,7 +1405,7 @@
 		if ( isnull )
 			continue;
 		if ( gserialized_get_type(geom) != POINTTYPE &&
@@ -1632,7 +1632,7 @@
 	GBOX gbox;
 	int result;
 	BOX *out = NULL;
 	/* Zero out flags */
 	gbox_init(&gbox);
@@ -1642,11 +1642,11 @@
 	/* Clean up memory */
 	lwfree(lwgeom);
 	PG_FREE_IF_COPY(pg_lwgeom, 0);
 	/* Null on failure */
 	if ( ! result )
 		PG_RETURN_NULL();
     out = lwalloc(sizeof(BOX));
 	out->low.x = gbox.xmin;
 	out->low.y = gbox.ymin;
@@ -1677,13 +1677,13 @@
 		/* must be the EMPTY geometry */
 		PG_RETURN_POINTER(geom);
 	if ( lwgeom_calculate_gbox(lwgeom, &box) == LW_FAILURE )
 	 * Alter envelope type so that a valid geometry is always
 	 * returned depending upon the size of the geometry. The
@@ -1815,7 +1815,7 @@
 		lwgeom_free(inlwgeom);
 		PG_RETURN_POINTER(ingeom);
 	outlwgeom = lwgeom_segmentize2d(inlwgeom, dist);
 	if ( ! outlwgeom ) {
 		/* Should only happen on interruption */
@@ -1831,7 +1831,7 @@
 	//lwgeom_free(outlwgeom); /* TODO fix lwgeom_clone / ptarray_clone_deep for consistent semantics */
 	PG_FREE_IF_COPY(ingeom, 0);
 	PG_RETURN_POINTER(outgeom);
@@ -2167,7 +2167,7 @@
 	point = lwgeom_as_lwpoint(lwgeom_from_gserialized(pglwg2));
 	linecopy = lwgeom_as_lwline(lwgeom_clone_deep(lwline_as_lwgeom(line)));
 	lwline_free(line);
 	if ( lwline_add_lwpoint(linecopy, point, where) == LW_FAILURE )
 		elog(ERROR, "Point insert failed");
@@ -2518,7 +2518,7 @@
 	result = cstring2text(geohash);
 	pfree(geohash);
 	PG_RETURN_TEXT_P(result);
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2016-06-14 10:29:08 UTC (rev 14945)
+++ trunk/postgis/postgis.sql.in	2016-06-15 09:14:27 UTC (rev 14946)
@@ -63,7 +63,7 @@
       RAISE DEBUG '% signature was deprecated in %. Please use %', oldname, version, newname;
     END IF;
 END;
-$$ LANGUAGE 'plpgsql' IMMUTABLE STRICT
+$$ LANGUAGE 'plpgsql' IMMUTABLE STRICT
 	COST 100;
@@ -272,7 +272,7 @@
 --  BOX2DF TYPE (INTERNAL ONLY)
--- Box2Df type is used by the GiST index bindings.
+-- Box2Df type is used by the GiST index bindings.
 -- In/out functions are stubs, as all access should be internal.
 -- Availability: 2.0.0
@@ -301,7 +301,7 @@
 --  GIDX TYPE (INTERNAL ONLY)
--- GIDX type is used by the N-D and GEOGRAPHY GiST index bindings.
+-- GIDX type is used by the N-D and GEOGRAPHY GiST index bindings.
@@ -418,50 +418,50 @@
-CREATE OR REPLACE FUNCTION geometry_gist_distance_2d(internal,geometry,int4)
-	RETURNS float8
+CREATE OR REPLACE FUNCTION geometry_gist_distance_2d(internal,geometry,int4)
+	RETURNS float8
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_distance_2d'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_consistent_2d(internal,geometry,int4)
-	RETURNS bool
+CREATE OR REPLACE FUNCTION geometry_gist_consistent_2d(internal,geometry,int4)
+	RETURNS bool
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent_2d'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_compress_2d(internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_compress_2d(internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME','gserialized_gist_compress_2d'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_penalty_2d(internal,internal,internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_penalty_2d(internal,internal,internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_penalty_2d'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_picksplit_2d(internal, internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_picksplit_2d(internal, internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_picksplit_2d'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_union_2d(bytea, internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_union_2d(bytea, internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_union_2d'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_same_2d(geom1 geometry, geom2 geometry, internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_same_2d(geom1 geometry, geom2 geometry, internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_same_2d'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_decompress_2d(internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_decompress_2d(internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_decompress_2d'
 	LANGUAGE 'c';
@@ -488,7 +488,7 @@
 	LANGUAGE 'c' STRICT _PARALLEL;
 -- Availability: 2.1.0
--- Given a table and a column, returns the statistics information stored by
+-- Given a table and a column, returns the statistics information stored by
 -- PostgreSQL, in a JSON text form. Mode determines whether the 2D statistics
 -- or the ND statistics are returned.
 CREATE OR REPLACE FUNCTION _postgis_stats(tbl regclass, att_name text, text default '2')
@@ -530,8 +530,8 @@
-CREATE OR REPLACE FUNCTION geometry_overlaps(geom1 geometry, geom2 geometry)
-	RETURNS boolean
+CREATE OR REPLACE FUNCTION geometry_overlaps(geom1 geometry, geom2 geometry)
+	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_overlaps_2d'
 	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
@@ -540,13 +540,13 @@
 CREATE OPERATOR && (
 	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_overlaps,
 	COMMUTATOR = '&&',
- 	RESTRICT = gserialized_gist_sel_2d,
-	JOIN = gserialized_gist_joinsel_2d
+	RESTRICT = gserialized_gist_sel_2d,
+	JOIN = gserialized_gist_joinsel_2d
-CREATE OR REPLACE FUNCTION geometry_same(geom1 geometry, geom2 geometry)
-	RETURNS boolean
+CREATE OR REPLACE FUNCTION geometry_same(geom1 geometry, geom2 geometry)
+	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_same_2d'
@@ -556,12 +556,12 @@
 	RESTRICT = contsel, JOIN = contjoinsel
--- As of 2.2.0 this no longer returns the centroid/centroid distance, it
+-- As of 2.2.0 this no longer returns the centroid/centroid distance, it
 -- returns the actual distance, to support the 'recheck' functionality
 -- enabled in the KNN operator
-CREATE OR REPLACE FUNCTION geometry_distance_centroid(geom1 geometry, geom2 geometry)
-	RETURNS float8
+CREATE OR REPLACE FUNCTION geometry_distance_centroid(geom1 geometry, geom2 geometry)
+	RETURNS float8
   AS 'MODULE_PATHNAME' ,'distance'
 #else
@@ -570,8 +570,8 @@
-CREATE OR REPLACE FUNCTION geometry_distance_box(geom1 geometry, geom2 geometry)
-	RETURNS float8
+CREATE OR REPLACE FUNCTION geometry_distance_box(geom1 geometry, geom2 geometry)
+	RETURNS float8
   AS 'MODULE_PATHNAME' ,'gserialized_distance_box_2d'
@@ -756,44 +756,44 @@
-CREATE OR REPLACE FUNCTION geometry_gist_consistent_nd(internal,geometry,int4)
-	RETURNS bool
+CREATE OR REPLACE FUNCTION geometry_gist_consistent_nd(internal,geometry,int4)
+	RETURNS bool
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_compress_nd(internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_compress_nd(internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME','gserialized_gist_compress'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_penalty_nd(internal,internal,internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_penalty_nd(internal,internal,internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_penalty'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_picksplit_nd(internal, internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_picksplit_nd(internal, internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_picksplit'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_union_nd(bytea, internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_union_nd(bytea, internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_union'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_same_nd(geometry, geometry, internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_same_nd(geometry, geometry, internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_same'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geometry_gist_decompress_nd(internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geometry_gist_decompress_nd(internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_decompress'
 	LANGUAGE 'c';
@@ -803,8 +803,8 @@
-CREATE OR REPLACE FUNCTION geometry_overlaps_nd(geometry, geometry)
-	RETURNS boolean
+CREATE OR REPLACE FUNCTION geometry_overlaps_nd(geometry, geometry)
+	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_overlaps'
@@ -813,7 +813,7 @@
 	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_overlaps_nd,
 	COMMUTATOR = '&&&',
 	RESTRICT = gserialized_gist_sel_nd,
-	JOIN = gserialized_gist_joinsel_nd
+	JOIN = gserialized_gist_joinsel_nd
 -- Availability: 2.2.0
@@ -979,10 +979,10 @@
 	LANGUAGE 'c' IMMUTABLE STRICT SECURITY DEFINER;
 -- Availability: 1.2.2
--- Deprecation in 2.1.0
+-- Deprecation in 2.1.0
 CREATE OR REPLACE FUNCTION ST_estimated_extent(text,text,text) RETURNS box2d AS
   $$ SELECT _postgis_deprecate('ST_Estimated_Extent', 'ST_EstimatedExtent', '2.1.0');
-    -- We use security invoker instead of security definer
+    -- We use security invoker instead of security definer
     -- to prevent malicious injection of a different same named function
     SELECT ST_EstimatedExtent($1, $2, $3);
@@ -998,10 +998,10 @@
 CREATE OR REPLACE FUNCTION ST_estimated_extent(text,text) RETURNS box2d AS
     -- to prevent malicious injection of a same named different function
     -- that would be run under elevated permissions
     SELECT ST_EstimatedExtent($1, $2);
@@ -1476,7 +1476,7 @@
 	AS 'MODULE_PATHNAME', 'LWGEOM_noop'
 	LANGUAGE 'c' VOLATILE STRICT
 	COST 10;
 -- Deprecation in 1.5.0
 CREATE OR REPLACE FUNCTION ST_zmflag(geometry)
 	RETURNS smallint
@@ -1497,7 +1497,7 @@
 	AS 'MODULE_PATHNAME','LWGEOM_asEWKT'
 	COST 750; --this looks suspicious, requires recheck
 CREATE OR REPLACE FUNCTION ST_AsTWKB(geom geometry, prec int4 default NULL, prec_z int4 default NULL, prec_m int4 default NULL, with_sizes boolean default NULL, with_boxes boolean default NULL)
 	RETURNS bytea
@@ -1625,7 +1625,7 @@
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_line_from_mpoint'
 CREATE OR REPLACE FUNCTION ST_MakeLine(geom1 geometry, geom2 geometry)
 	RETURNS geometry
@@ -1841,15 +1841,15 @@
   i integer;
   j integer;
   g geometry;
 BEGIN
   -- RAISE DEBUG '%,%', cur_path, ST_GeometryType(the_geom);
   -- Special case collections : iterate and return the DumpPoints of the geometries
   IF (ST_IsCollection(the_geom)) THEN
     i = 1;
     FOR tmp2 IN SELECT (ST_Dump(the_geom)).* LOOP
@@ -1857,27 +1857,27 @@
 	    RETURN NEXT tmp;
       END LOOP;
       i = i + 1;
     END LOOP;
     RETURN;
   END IF;
   -- Special case (POLYGON) : return the points of the rings of a polygon
   IF (ST_GeometryType(the_geom) = 'ST_Polygon') THEN
     FOR tmp IN SELECT * FROM _ST_DumpPoints(ST_ExteriorRing(the_geom), cur_path || ARRAY[1]) LOOP
       RETURN NEXT tmp;
     END LOOP;
     j := ST_NumInteriorRings(the_geom);
     FOR i IN 1..j LOOP
         FOR tmp IN SELECT * FROM _ST_DumpPoints(ST_InteriorRingN(the_geom, i), cur_path || ARRAY[i+1]) LOOP
           RETURN NEXT tmp;
         END LOOP;
     END LOOP;
     RETURN;
   END IF;
@@ -1887,11 +1887,11 @@
       RETURN NEXT tmp;
     END LOOP;
     RETURN;
   END IF;
   -- Special case (POINT) : return the point
   IF (ST_GeometryType(the_geom) = 'ST_Point') THEN
@@ -1918,14 +1918,14 @@
     tmp.geom := ST_PointN(the_geom, i);
     RETURN NEXT tmp;
   END LOOP;
 END
 $$ LANGUAGE plpgsql;
 -- ST_DumpPoints()
--- This function mimicks that of ST_Dump for collections, but this function
+-- This function mimicks that of ST_Dump for collections, but this function
 -- that returns a path and all the points that make up a particular geometry.
 -- Availability: 1.5.0
 CREATE OR REPLACE FUNCTION ST_DumpPoints(geometry)
@@ -1959,7 +1959,7 @@
 -- geometry_columns table.
 -- Availability: 1.4.0
 -- Revised: 2.0.0 -- no longer deletes from geometry_columns
--- Has new use_typmod option that defaults to true.
+-- Has new use_typmod option that defaults to true.
 -- If use typmod is  set to false will use old constraint behavior.
 -- Will only touch table missing typmod or geometry constraints
@@ -2012,7 +2012,7 @@
 		AND a.atttypid = t.oid
 		AND a.attrelid = c.oid
 		AND c.relnamespace = n.oid
-		AND n.nspname NOT ILIKE 'pg_temp%' AND c.relname != 'raster_columns'
+		AND n.nspname NOT ILIKE 'pg_temp%' AND c.relname != 'raster_columns'
 	LOOP
 		inserted := inserted + populate_geometry_columns(gcs.oid, use_typmod);
@@ -2088,20 +2088,20 @@
 	LOOP
         RAISE DEBUG 'Processing column %.%.%', gcs.nspname, gcs.relname, gcs.attname;
         gc_is_valid := true;
         -- Find the srid, coord_dimension, and type of current geometry
         -- in geometry_columns -- which is now a view
-        SELECT type, srid, coord_dimension INTO gc_old
-            FROM geometry_columns
-            WHERE f_table_schema = gcs.nspname AND f_table_name = gcs.relname AND f_geometry_column = gcs.attname;
+        SELECT type, srid, coord_dimension INTO gc_old
+            FROM geometry_columns
+            WHERE f_table_schema = gcs.nspname AND f_table_name = gcs.relname AND f_geometry_column = gcs.attname;
         IF upper(gc_old.type) = 'GEOMETRY' THEN
         -- This is an unconstrained geometry we need to do something
         -- We need to figure out what to set the type by inspecting the data
             EXECUTE 'SELECT st_srid(' || quote_ident(gcs.attname) || ') As srid, GeometryType(' || quote_ident(gcs.attname) || ') As type, ST_NDims(' || quote_ident(gcs.attname) || ') As dims ' ||
-                     ' FROM ONLY ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) ||
+                     ' FROM ONLY ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) ||
                      ' WHERE ' || quote_ident(gcs.attname) || ' IS NOT NULL LIMIT 1;'
                 INTO gc;
             IF gc IS NULL THEN -- there is no data so we can not determine geometry type
@@ -2109,10 +2109,10 @@
             	RETURN 0;
             END IF;
             gsrid := gc.srid; gtype := gc.type; gndims := gc.dims;
             IF use_typmod THEN
                 BEGIN
-                    EXECUTE 'ALTER TABLE ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) || ' ALTER COLUMN ' || quote_ident(gcs.attname) ||
+                    EXECUTE 'ALTER TABLE ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) || ' ALTER COLUMN ' || quote_ident(gcs.attname) ||
                         ' TYPE geometry(' || postgis_type_name(gtype, gndims, true) || ', ' || gsrid::text  || ') ';
                     inserted := inserted + 1;
                 EXCEPTION
@@ -2120,14 +2120,14 @@
                         RAISE WARNING 'Could not convert ''%'' in ''%.%'' to use typmod with srid %, type %: %', quote_ident(gcs.attname), quote_ident(gcs.nspname), quote_ident(gcs.relname), gsrid, postgis_type_name(gtype, gndims, true), SQLERRM;
                             gc_is_valid := false;
                 END;
             ELSE
                 -- Try to apply srid check to column
             	constraint_successful = false;
                 IF (gsrid > 0 AND postgis_constraint_srid(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
                     BEGIN
-                        EXECUTE 'ALTER TABLE ONLY ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) ||
-                                 ' ADD CONSTRAINT ' || quote_ident('enforce_srid_' || gcs.attname) ||
+                        EXECUTE 'ALTER TABLE ONLY ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) ||
+                                 ' ADD CONSTRAINT ' || quote_ident('enforce_srid_' || gcs.attname) ||
                                  ' CHECK (st_srid(' || quote_ident(gcs.attname) || ') = ' || gsrid || ')';
                         constraint_successful := true;
                     EXCEPTION
@@ -2136,7 +2136,7 @@
                     END;
                 END IF;
                 -- Try to apply ndims check to column
                 IF (gndims IS NOT NULL AND postgis_constraint_dims(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
                     BEGIN
@@ -2150,7 +2150,7 @@
                     END;
                 END IF;
                 -- Try to apply geometrytype check to column
                 IF (gtype IS NOT NULL AND postgis_constraint_type(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
                     BEGIN
@@ -2168,7 +2168,7 @@
                 IF constraint_successful THEN
                 END IF;
-            END IF;
+            END IF;
 	    END IF;
 	END LOOP;
@@ -2319,7 +2319,7 @@
             ') = ' || new_srid::text || ')' ;
         RAISE DEBUG '%', sql;
         EXECUTE sql;
         sql := 'ALTER TABLE ' ||
             quote_ident(real_schema) || '.' || quote_ident(table_name)
             || ' ADD CONSTRAINT '
@@ -2328,7 +2328,7 @@
             ') = ' || new_dim::text || ')' ;
         EXECUTE sql;
         IF ( NOT (new_type = 'GEOMETRY')) THEN
                 quote_ident(real_schema) || '.' || quote_ident(table_name) || ' ADD CONSTRAINT ' ||
@@ -2620,34 +2620,34 @@
 		END IF;
 	END IF;
-	IF postgis_constraint_srid(real_schema, table_name, column_name) IS NOT NULL THEN
+	IF postgis_constraint_srid(real_schema, table_name, column_name) IS NOT NULL THEN
 	-- srid was enforced with constraints before, keep it that way.
         -- Make up constraint name
         cname = 'enforce_srid_'  || column_name;
         -- Drop enforce_srid constraint
         EXECUTE 'ALTER TABLE ' || quote_ident(real_schema) ||
             ' DROP constraint ' || quote_ident(cname);
         -- Update geometries SRID
         EXECUTE 'UPDATE ' || quote_ident(real_schema) ||
             ' SET ' || quote_ident(column_name) ||
             ' = ST_SetSRID(' || quote_ident(column_name) ||
             ', ' || new_srid::text || ')';
         -- Reset enforce_srid constraint
             ' ADD constraint ' || quote_ident(cname) ||
             ' CHECK (st_srid(' || quote_ident(column_name) ||
             ') = ' || new_srid::text || ')';
-    ELSE
+    ELSE
         -- We will use typmod to enforce if no srid constraints
-        -- We are using postgis_type_name to lookup the new name
-        -- (in case Paul changes his mind and flips geometry_columns to return old upper case name)
-        EXECUTE 'ALTER TABLE ' || quote_ident(real_schema) || '.' || quote_ident(table_name) ||
+        -- We are using postgis_type_name to lookup the new name
+        -- (in case Paul changes his mind and flips geometry_columns to return old upper case name)
+        EXECUTE 'ALTER TABLE ' || quote_ident(real_schema) || '.' || quote_ident(table_name) ||
         ' ALTER COLUMN ' || quote_ident(column_name) || ' TYPE  geometry(' || postgis_type_name(myrec.type, myrec.coord_dimension, true) || ', ' || new_srid::text || ') USING ST_SetSRID(' || quote_ident(column_name) || ',' || new_srid::text || ');' ;
     END IF;
@@ -2982,7 +2982,7 @@
 -- CASTS
 CREATE OR REPLACE FUNCTION box2d(geometry)
 	RETURNS box2d
 	AS 'MODULE_PATHNAME','LWGEOM_to_BOX2D'
@@ -3059,7 +3059,7 @@
 CREATE CAST (geometry AS box2d) WITH FUNCTION box2d(geometry) AS IMPLICIT;
 CREATE CAST (geometry AS box3d) WITH FUNCTION box3d(geometry) AS IMPLICIT;
--- ticket: 2262 changed 2.1.0 to assignment to prevent PostGIS
+-- ticket: 2262 changed 2.1.0 to assignment to prevent PostGIS
 -- from misusing PostgreSQL geometric functions
 CREATE CAST (geometry AS box) WITH FUNCTION box(geometry) AS ASSIGNMENT;
@@ -3091,14 +3091,14 @@
 	AS 'MODULE_PATHNAME', 'LWGEOM_simplify2d'
 	COST 50; -- COST guessed from ST_Simplify(geometry, float8)
 CREATE OR REPLACE FUNCTION ST_SimplifyVW(geometry,  float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_SetEffectiveArea'
 CREATE OR REPLACE FUNCTION ST_SetEffectiveArea(geometry,  float8 default -1, integer default 1)
 	RETURNS geometry
@@ -3155,7 +3155,7 @@
 CREATE OR REPLACE FUNCTION ST_line_interpolate_point(geometry, float8)
 	RETURNS geometry AS
   $$ SELECT _postgis_deprecate('ST_Line_Interpolate_Point', 'ST_LineInterpolatePoint', '2.1.0');
@@ -3170,7 +3170,7 @@
 CREATE OR REPLACE FUNCTION ST_line_substring(geometry, float8, float8)
 	RETURNS geometry AS
   $$ SELECT _postgis_deprecate('ST_Line_Substring', 'ST_LineSubstring', '2.1.0');
@@ -3185,7 +3185,7 @@
 CREATE OR REPLACE FUNCTION ST_line_locate_point(geom1 geometry, geom2 geometry)
 	RETURNS float8 AS
   $$ SELECT _postgis_deprecate('ST_Line_Locate_Point', 'ST_LineLocatePoint', '2.1.0');
@@ -3210,9 +3210,9 @@
 	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
-CREATE OR REPLACE FUNCTION ST_AddMeasure(geometry, float8, float8)
-	RETURNS geometry
-	AS 'MODULE_PATHNAME', 'ST_AddMeasure'
+CREATE OR REPLACE FUNCTION ST_AddMeasure(geometry, float8, float8)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'ST_AddMeasure'
@@ -3221,13 +3221,13 @@
 CREATE OR REPLACE FUNCTION ST_ClosestPointOfApproach(geometry, geometry)
-	RETURNS float8
-	AS 'MODULE_PATHNAME', 'ST_ClosestPointOfApproach'
+	RETURNS float8
+	AS 'MODULE_PATHNAME', 'ST_ClosestPointOfApproach'
 CREATE OR REPLACE FUNCTION ST_DistanceCPA(geometry, geometry)
-	RETURNS float8
+	RETURNS float8
 	AS 'MODULE_PATHNAME', 'ST_DistanceCPA'
@@ -3239,10 +3239,10 @@
 CREATE OR REPLACE FUNCTION ST_IsValidTrajectory(geometry)
-	RETURNS bool
-	AS 'MODULE_PATHNAME', 'ST_IsValidTrajectory'
+	RETURNS bool
+	AS 'MODULE_PATHNAME', 'ST_IsValidTrajectory'
 -- GEOS
@@ -3506,13 +3506,13 @@
 -- 	- Simple (lineal components)
 --	- Valid (polygonal components)
 --	- Obeying the RHR (if polygonal)
---	- Simplified of consecutive duplicated points
+--	- Simplified of consecutive duplicated points
 -- Ensuring:
 --	- No input vertexes are discarded (except consecutive repeated ones)
 --	- Output geometry type matches input
 -- Returns NULL on failure.
 -- Requires: GEOS-3.3.0
 CREATE OR REPLACE FUNCTION ST_CleanGeometry(geometry)
@@ -3532,7 +3532,7 @@
 -- Note that multi-part geometries will be returned exploded,
 -- no matter relation to blade.
 CREATE OR REPLACE FUNCTION ST_Split(geom1 geometry, geom2 geometry)
@@ -3554,7 +3554,7 @@
 -- The paths themselves are given in the direction of the
 -- first geometry.
 -- Requires GEOS >= 3.3.0
@@ -3630,8 +3630,8 @@
 -- If a tolerance is given it will be used to snap the input points
 -- each-other.
 -- Requires GEOS >= 3.4.0
@@ -3652,7 +3652,7 @@
 -- By default, the diagram will be extended to an envelope larger than the
 -- input points.
--- If a second geometry is supplied, the diagram will be extended to fill the
+-- If a second geometry is supplied, the diagram will be extended to fill the
 -- envelope of the second geometry, unless that is smaller than the default
 -- envelope.
@@ -3986,7 +3986,7 @@
 	RETURNS boolean
 	AS 'SELECT $1 && $2 AND _ST_Intersects($1,$2)'
 	LANGUAGE 'sql' IMMUTABLE _PARALLEL;
 -- PostGIS equivalent function: crosses(geom1 geometry, geom2 geometry)
 CREATE OR REPLACE FUNCTION _ST_Crosses(geom1 geometry, geom2 geometry)
 	RETURNS boolean
@@ -4109,8 +4109,8 @@
 	AS 'MODULE_PATHNAME', 'centroid'
 	COST 100;
 -- Availability: 2.3.0
 CREATE OR REPLACE FUNCTION ST_GeometricMedian(g geometry, tolerance float8 DEFAULT NULL, max_iter int DEFAULT 10000, fail_if_not_converged boolean DEFAULT false)
 	RETURNS geometry
@@ -4157,11 +4157,11 @@
 	AS 'SELECT $1 ~= $2 AND _ST_Equals($1,$2)'
--- Deprecation in 1.2.3
--- TODO: drop in 2.0.0 !
-CREATE OR REPLACE FUNCTION Equals(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'MODULE_PATHNAME','ST_Equals'
+-- Deprecation in 1.2.3
+-- TODO: drop in 2.0.0 !
+CREATE OR REPLACE FUNCTION Equals(geom1 geometry, geom2 geometry)
+	RETURNS boolean
+	AS 'MODULE_PATHNAME','ST_Equals'
@@ -4262,7 +4262,7 @@
 	LANGUAGE 'c' IMMUTABLE _PARALLEL
 	COST 2500;
--- ST_AsGML(version, geom) / precision=15
+-- ST_AsGML(version, geom) / precision=15
 -- Availability: 1.3.2
 -- ST_AsGML(version, geom, precision)
@@ -4496,14 +4496,14 @@
 	AS 'MODULE_PATHNAME','LWGEOM_asBinary'
 	COST 10;
 -- PostGIS equivalent of old function: AsBinary(geometry)
 CREATE OR REPLACE FUNCTION ST_AsBinary(geometry)
 	RETURNS bytea
 	COST 10;
 -- PostGIS equivalent function: AsText(geometry)
 CREATE OR REPLACE FUNCTION ST_AsText(geometry)
 	RETURNS TEXT
@@ -4534,13 +4534,13 @@
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_from_text'
 -- PostGIS equivalent function: ST_GeometryFromText(text)
 -- SQL/MM alias for ST_GeomFromText
 CREATE OR REPLACE FUNCTION ST_WKTToSQL(text)
 	RETURNS geometry
-	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
 CREATE OR REPLACE FUNCTION ST_PointFromText(text)
@@ -4986,13 +4986,13 @@
 CREATE OR REPLACE FUNCTION _ST_MaxDistance(geom1 geometry, geom2 geometry)
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'LWGEOM_maxdistance2d_linestring'
 CREATE OR REPLACE FUNCTION ST_MaxDistance(geom1 geometry, geom2 geometry)
 	RETURNS float8
 	AS 'SELECT _ST_MaxDistance(ST_ConvexHull($1), ST_ConvexHull($2))'
-	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
+	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
 CREATE OR REPLACE FUNCTION ST_ClosestPoint(geom1 geometry, geom2 geometry)
 	RETURNS geometry
@@ -5012,18 +5012,18 @@
 CREATE OR REPLACE FUNCTION ST_LongestLine(geom1 geometry, geom2 geometry)
 	RETURNS geometry
 	AS 'SELECT _ST_LongestLine(ST_ConvexHull($1), ST_ConvexHull($2))'
 CREATE OR REPLACE FUNCTION _ST_DFullyWithin(geom1 geometry, geom2 geometry,float8)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_dfullywithin'
 CREATE OR REPLACE FUNCTION ST_DFullyWithin(geom1 geometry, geom2 geometry, float8)
 	RETURNS boolean
 	AS 'SELECT $1 && ST_Expand($2,$3) AND $2 && ST_Expand($1,$3) AND _ST_DFullyWithin(ST_ConvexHull($1), ST_ConvexHull($2), $3)'
-	LANGUAGE 'sql' IMMUTABLE;
+	LANGUAGE 'sql' IMMUTABLE;
 CREATE OR REPLACE FUNCTION ST_SwapOrdinates(geom geometry, ords cstring)
 	RETURNS geometry
@@ -5038,7 +5038,7 @@
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_FlipCoordinates'
-	COST 25;
+	COST 25;
 -- SFSQL 1.1
@@ -5151,12 +5151,12 @@
 -- New helper function so we can keep list of valid geometry types in one place --
 -- Maps old names to pramsey beautiful names but can take old name or new name as input
 -- By default returns new name but can be overridden to return old name for old constraint like support
-CREATE OR REPLACE FUNCTION postgis_type_name(geomname varchar, coord_dimension integer, use_new_name boolean DEFAULT true)
+CREATE OR REPLACE FUNCTION postgis_type_name(geomname varchar, coord_dimension integer, use_new_name boolean DEFAULT true)
 	RETURNS varchar
 AS
  SELECT CASE WHEN $3 THEN new_name ELSE old_name END As geomname
- 	FROM
+	FROM
  	( VALUES
  		 ('GEOMETRY', 'Geometry', 2) ,
  		 	('GEOMETRY', 'GeometryZ', 3) ,
@@ -5165,67 +5165,67 @@
 			('GEOMETRYCOLLECTION', 'GeometryCollectionZ', 3) ,
 			('GEOMETRYCOLLECTIONM', 'GeometryCollectionM', 3) ,
 			('GEOMETRYCOLLECTION', 'GeometryCollectionZM', 4) ,
 			('POINT', 'Point',2) ,
 			('POINTM','PointM',3) ,
 			('POINT', 'PointZ',3) ,
 			('POINT', 'PointZM',4) ,
 			('MULTIPOINT','MultiPoint',2) ,
 			('MULTIPOINT','MultiPointZ',3) ,
 			('MULTIPOINTM','MultiPointM',3) ,
 			('MULTIPOINT','MultiPointZM',4) ,
 			('POLYGON', 'Polygon',2) ,
 			('POLYGON', 'PolygonZ',3) ,
 			('POLYGONM', 'PolygonM',3) ,
 			('POLYGON', 'PolygonZM',4) ,
 			('MULTIPOLYGON', 'MultiPolygon',2) ,
 			('MULTIPOLYGON', 'MultiPolygonZ',3) ,
 			('MULTIPOLYGONM', 'MultiPolygonM',3) ,
 			('MULTIPOLYGON', 'MultiPolygonZM',4) ,
 			('MULTILINESTRING', 'MultiLineString',2) ,
 			('MULTILINESTRING', 'MultiLineStringZ',3) ,
 			('MULTILINESTRINGM', 'MultiLineStringM',3) ,
 			('MULTILINESTRING', 'MultiLineStringZM',4) ,
 			('LINESTRING', 'LineString',2) ,
 			('LINESTRING', 'LineStringZ',3) ,
 			('LINESTRINGM', 'LineStringM',3) ,
 			('LINESTRING', 'LineStringZM',4) ,
 			('CIRCULARSTRING', 'CircularString',2) ,
 			('CIRCULARSTRING', 'CircularStringZ',3) ,
 			('CIRCULARSTRINGM', 'CircularStringM',3) ,
 			('CIRCULARSTRING', 'CircularStringZM',4) ,
 			('COMPOUNDCURVE', 'CompoundCurve',2) ,
 			('COMPOUNDCURVE', 'CompoundCurveZ',3) ,
 			('COMPOUNDCURVEM', 'CompoundCurveM',3) ,
 			('COMPOUNDCURVE', 'CompoundCurveZM',4) ,
 			('CURVEPOLYGON', 'CurvePolygon',2) ,
 			('CURVEPOLYGON', 'CurvePolygonZ',3) ,
 			('CURVEPOLYGONM', 'CurvePolygonM',3) ,
 			('CURVEPOLYGON', 'CurvePolygonZM',4) ,
 			('MULTICURVE', 'MultiCurve',2 ) ,
 			('MULTICURVE', 'MultiCurveZ',3 ) ,
 			('MULTICURVEM', 'MultiCurveM',3 ) ,
 			('MULTICURVE', 'MultiCurveZM',4 ) ,
 			('MULTISURFACE', 'MultiSurface', 2) ,
 			('MULTISURFACE', 'MultiSurfaceZ', 3) ,
 			('MULTISURFACEM', 'MultiSurfaceM', 3) ,
 			('MULTISURFACE', 'MultiSurfaceZM', 4) ,
 			('POLYHEDRALSURFACE', 'PolyhedralSurface',2) ,
 			('POLYHEDRALSURFACE', 'PolyhedralSurfaceZ',3) ,
 			('POLYHEDRALSURFACEM', 'PolyhedralSurfaceM',3) ,
 			('POLYHEDRALSURFACE', 'PolyhedralSurfaceZM',4) ,
 			('TRIANGLE', 'Triangle',2) ,
 			('TRIANGLE', 'TriangleZ',3) ,
 			('TRIANGLEM', 'TriangleM',3) ,
@@ -5281,7 +5281,7 @@
 -- Deprecation in 2.2.0
 CREATE OR REPLACE FUNCTION postgis_constraint_type(geomschema text, geomtable text, geomcolumn text) RETURNS varchar AS
-SELECT  replace(split_part(s.consrc, '''', 2), ')', '')::varchar
+SELECT  replace(split_part(s.consrc, '''', 2), ')', '')::varchar
 		 FROM pg_class c, pg_namespace n, pg_attribute a, pg_constraint s
 		 WHERE n.nspname = $1
 		 AND c.relname = $2
@@ -5297,7 +5297,7 @@
 -- Changed: 2.1.8 significant performance improvement for constraint based columns
 -- Changed: 2.2.0 get rid of scheman, table, column cast to improve performance
-CREATE OR REPLACE VIEW geometry_columns AS
+CREATE OR REPLACE VIEW geometry_columns AS
  SELECT current_database()::character varying(256) AS f_table_catalog,
     n.nspname AS f_table_schema,
     c.relname AS f_table_name,
@@ -5313,25 +5313,25 @@
             s.conrelid,
             s.conkey, replace(split_part(s.consrc, ''''::text, 2), ')'::text, ''::text) As type
            FROM pg_constraint AS s
-          WHERE s.consrc ~~* '%geometrytype(% = %'::text
+          WHERE s.consrc ~~* '%geometrytype(% = %'::text
 ) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
      LEFT JOIN ( SELECT s.connamespace,
             s.conrelid,
             s.conkey, replace(split_part(s.consrc, ' = '::text, 2), ')'::text, ''::text)::integer As ndims
           WHERE s.consrc ~~* '%ndims(% = %'::text
 ) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
             s.conrelid,
             s.conkey, replace(replace(split_part(s.consrc, ' = '::text, 2), ')'::text, ''::text), '('::text, ''::text)::integer As srid
           WHERE s.consrc ~~* '%srid(% = %'::text
 ) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
-  WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char"]))
-  AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
+  WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char"]))
+  AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
   AND NOT pg_is_other_temp_schema(c.relnamespace) AND has_table_privilege(c.oid, 'SELECT'::text);
@@ -5360,12 +5360,12 @@
 	AS 'MODULE_PATHNAME', 'distance3d'
 	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DMaxDistance(geom1 geometry, geom2 geometry)
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'LWGEOM_maxdistance3d'
-	COST 100;
+	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DClosestPoint(geom1 geometry, geom2 geometry)
 	RETURNS geometry
@@ -5384,25 +5384,25 @@
 	AS 'MODULE_PATHNAME', 'LWGEOM_longestline3d'
 	COST 100;
 CREATE OR REPLACE FUNCTION _ST_3DDWithin(geom1 geometry, geom2 geometry,float8)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_dwithin3d'
 	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DDWithin(geom1 geometry, geom2 geometry,float8)
 	RETURNS boolean
 	AS 'SELECT $1 && ST_Expand($2,$3) AND $2 && ST_Expand($1,$3) AND _ST_3DDWithin($1, $2, $3)'
 	COST 100;
 CREATE OR REPLACE FUNCTION _ST_3DDFullyWithin(geom1 geometry, geom2 geometry,float8)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_dfullywithin3d'
 	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DDFullyWithin(geom1 geometry, geom2 geometry,float8)
 	RETURNS boolean
 	AS 'SELECT $1 && ST_Expand($2,$3) AND $2 && ST_Expand($1,$3) AND _ST_3DDFullyWithin($1, $2, $3)'
@@ -5414,14 +5414,14 @@
 	AS 'MODULE_PATHNAME','intersects3d'
 	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DIntersects(geom1 geometry, geom2 geometry)
 	RETURNS boolean
 	AS 'SELECT $1 && $2 AND _ST_3DIntersects($1, $2)'
 	COST 100;
 -- SQL-MM
@@ -5430,7 +5430,7 @@
 	RETURNS smallint
 	AS 'MODULE_PATHNAME', 'LWGEOM_ndims'
-	COST 5;
+	COST 5;
 -- SQL-MM
@@ -5464,7 +5464,7 @@
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_line_desegmentize'
 CREATE OR REPLACE FUNCTION _ST_OrderingEquals(GeometryA geometry, GeometryB geometry)
 	RETURNS boolean
@@ -5475,11 +5475,11 @@
 -- Availability: 1.3.0
 CREATE OR REPLACE FUNCTION ST_OrderingEquals(GeometryA geometry, GeometryB geometry)
 	RETURNS boolean
-	AS $$
+	AS $$
 	SELECT $1 ~= $2 AND _ST_OrderingEquals($1, $2)
 -- SQL/MM - SQL Functions on type ST_Point
@@ -5488,23 +5488,23 @@
 CREATE OR REPLACE FUNCTION ST_Point(float8, float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_makepoint'
 -- PostGIS equivalent function: ST_MakePolygon(Geometry geometry)
 CREATE OR REPLACE FUNCTION ST_Polygon(geometry, int)
 	RETURNS geometry
-	AS $$
+	AS $$
 	SELECT ST_SetSRID(ST_MakePolygon($1), $2)
 -- PostGIS equivalent function: GeomFromWKB(WKB bytea))
 -- Note: Defaults to an SRID=-1, not 0 as per SQL/MM specs.
 CREATE OR REPLACE FUNCTION ST_WKBToSQL(WKB bytea)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_from_WKB'
 -- Linear referencing functions
@@ -5513,7 +5513,7 @@
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_LocateBetween'
 CREATE OR REPLACE FUNCTION ST_LocateAlong(Geometry geometry, Measure float8, LeftRightOffset float8 default 0.0)
 	RETURNS geometry
@@ -5550,7 +5550,7 @@
 CREATE OR REPLACE FUNCTION _st_concavehull(param_inputgeom geometry)
   RETURNS geometry AS
-	DECLARE
+	DECLARE
 	vexhull GEOMETRY;
 	var_resultgeom geometry;
 	var_inputgeom geometry;
@@ -5561,7 +5561,7 @@
 	var_tempgeom geometry;
 	scale_factor integer := 1;
 	i integer;
 	BEGIN
 		-- First compute the ConvexHull of the geometry
@@ -5587,20 +5587,20 @@
 		cavering := ST_Collect(
 			ARRAY(
-				SELECT
+				SELECT
 					ST_ClosestPoint(var_inputgeom, pt ) As the_geom
 					FROM (
 						SELECT  ST_PointN(vexring, n ) As pt, n
-							FROM
+							FROM
 							generate_series(1, ST_NPoints(vexring) ) As n
 						) As pt
-		var_resultgeom := ST_MakeLine(geom)
+		var_resultgeom := ST_MakeLine(geom)
 			FROM ST_Dump(cavering) As foo;
 		IF ST_IsSimple(var_resultgeom) THEN
@@ -5610,16 +5610,16 @@
 			--RAISE NOTICE 'is not Simple: %', var_resultgeom;
 			var_resultgeom := ST_ConvexHull(var_resultgeom);
 		END IF;
 		IF scale_factor > 1 THEN -- scale the result back
 			var_resultgeom := ST_Scale(var_resultgeom, 1/scale_factor, 1/scale_factor);
 		END IF;
 		RETURN var_resultgeom;
 	END;
   LANGUAGE plpgsql IMMUTABLE STRICT _PARALLEL;
 CREATE OR REPLACE FUNCTION ST_ConcaveHull(param_geom geometry, param_pctconvex float, param_allow_holes boolean DEFAULT false) RETURNS geometry AS
 	DECLARE
@@ -5639,7 +5639,7 @@
 	BEGIN
 		-- We start with convex hull as our base
 		var_resultgeom := var_convhull;
 		IF param_pctconvex = 1 THEN
 			return var_resultgeom;
 		ELSIF ST_GeometryType(var_param_geom) = 'ST_Polygon' THEN -- it is as concave as it is going to get
@@ -5655,7 +5655,7 @@
 			var_enline := ST_Boundary(ST_Envelope(var_param_geom));
 			var_buf := ST_Length(var_enline)/1000.0;
 			IF ST_GeometryType(var_param_geom) = 'ST_MultiPoint' AND ST_NumGeometries(var_param_geom) BETWEEN 4 and 200 THEN
-			-- we make polygons out of points since they are easier to cave in.
+			-- we make polygons out of points since they are easier to cave in.
 			-- Note we limit to between 4 and 200 points because this process is slow and gets quadratically slow
 				var_buf := sqrt(ST_Area(var_convhull)*0.8/(ST_NumGeometries(var_param_geom)*ST_NumGeometries(var_param_geom)));
 				var_atempgeoms := ARRAY(SELECT geom FROM ST_DumpPoints(var_param_geom));
@@ -5665,7 +5665,7 @@
 						-- fuse near neighbors together
 						SELECT DISTINCT ON (i) i,  ST_Distance(var_atempgeoms[i],var_atempgeoms[j]), ST_Buffer(ST_MakeLine(var_atempgeoms[i], var_atempgeoms[j]) , var_buf*5, 'quad_segs=3') As geom
 								FROM generate_series(1,array_upper(var_atempgeoms, 1)) As i
-									INNER JOIN generate_series(1,array_upper(var_atempgeoms, 1)) As j
+									INNER JOIN generate_series(1,array_upper(var_atempgeoms, 1)) As j
 										ON (
 								 NOT ST_Intersects(var_atempgeoms[i],var_atempgeoms[j])
 									AND ST_DWithin(var_atempgeoms[i],var_atempgeoms[j], var_buf*10)
@@ -5674,10 +5674,10 @@
 						-- catch the ones with no near neighbors
 								SELECT i, 0, ST_Buffer(var_atempgeoms[i] , var_buf*10, 'quad_segs=3') As geom
-									LEFT JOIN generate_series(ceiling(array_upper(var_atempgeoms,1)/2)::integer,array_upper(var_atempgeoms, 1)) As j
+									LEFT JOIN generate_series(ceiling(array_upper(var_atempgeoms,1)/2)::integer,array_upper(var_atempgeoms, 1)) As j
 										ON (
-									AND ST_DWithin(var_atempgeoms[i],var_atempgeoms[j], var_buf*10)
+									AND ST_DWithin(var_atempgeoms[i],var_atempgeoms[j], var_buf*10)
 									WHERE j IS NULL
 								ORDER BY 1, 2
@@ -5691,7 +5691,7 @@
 					END IF;
 					return var_param_geom;
 				ELSIF ST_IsValid(var_tempgeom) THEN
-					var_param_geom := ST_ForceSFS(ST_Intersection(var_tempgeom, var_convhull));
+					var_param_geom := ST_ForceSFS(ST_Intersection(var_tempgeom, var_convhull));
 				END IF;
 			END IF;
@@ -5717,16 +5717,16 @@
                     FOR i in 1 .. 4 LOOP
                        var_geoms[i] := ST_MakePolygon(ST_MakeLine(ARRAY[ST_PointN(var_enline,i), ST_PointN(var_enline,i+1), var_cent, ST_PointN(var_enline,i)]));
                        var_geoms[i] := ST_ForceSFS(ST_Intersection(var_param_geom, ST_Buffer(var_geoms[i],var_buf)));
-                       IF ST_IsValid(var_geoms[i]) THEN
+                       IF ST_IsValid(var_geoms[i]) THEN
                        ELSE
                             var_geoms[i] := ST_BuildArea(ST_MakeLine(ARRAY[ST_PointN(var_enline,i), ST_PointN(var_enline,i+1), var_cent, ST_PointN(var_enline,i)]));
-                       END IF;
+                       END IF;
                     END LOOP;
-                    var_tempgeom := ST_Union(ARRAY[ST_ConvexHull(var_geoms[1]), ST_ConvexHull(var_geoms[2]) , ST_ConvexHull(var_geoms[3]), ST_ConvexHull(var_geoms[4])]);
+                    var_tempgeom := ST_Union(ARRAY[ST_ConvexHull(var_geoms[1]), ST_ConvexHull(var_geoms[2]) , ST_ConvexHull(var_geoms[3]), ST_ConvexHull(var_geoms[4])]);
                     --RAISE NOTICE 'Curr vex % ', ST_AsText(var_tempgeom);
                     IF ST_Area(var_tempgeom) <= var_newarea AND ST_IsValid(var_tempgeom)  THEN --AND ST_GeometryType(var_tempgeom) ILIKE '%Polygon'
                         var_tempgeom := ST_Buffer(ST_ConcaveHull(var_geoms[1],least(param_pctconvex + param_pctconvex/var_div),true),var_buf, 'quad_segs=2');
                         FOR i IN 1 .. 4 LOOP
                             var_geoms[i] := ST_Buffer(ST_ConcaveHull(var_geoms[i],least(param_pctconvex + param_pctconvex/var_div),true), var_buf, 'quad_segs=2');
@@ -5735,7 +5735,7 @@
                             ELSE
                                 RAISE NOTICE 'Not valid % %', i, ST_AsText(var_tempgeom);
                                 var_tempgeom := ST_Union(var_tempgeom, ST_ConvexHull(var_geoms[i]));
-                            END IF;
+                            END IF;
                         END LOOP;
                         --RAISE NOTICE 'Curr concave % ', ST_AsText(var_tempgeom);
@@ -5755,7 +5755,7 @@
                             var_resultgeom := ST_Buffer(var_tempgeom,var_buf, 'quad_segs=2');
                         END IF;
                     END IF;
-                    IF param_allow_holes = false THEN
+                    IF param_allow_holes = false THEN
                     -- only keep exterior ring since we do not want holes
                         var_resultgeom := ST_MakePolygon(ST_ExteriorRing(var_resultgeom));
                     END IF;
@@ -5781,7 +5781,7 @@
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asX3D'
 	LANGUAGE 'c' IMMUTABLE;
 -- ST_AsX3D(geom, precision, options)
 CREATE OR REPLACE FUNCTION ST_AsX3D(geom geometry, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0)
 	RETURNS TEXT
