[postgis-tickets] r14952 - Style only change: remove trailing spaces
Sandro Santilli strk at kbt.io
Wed Jun 15 09:28:28 PDT 2016
Author: strk
Date: 2016-06-15 09:28:28 -0700 (Wed, 15 Jun 2016)
New Revision: 14952
   trunk/liblwgeom/ptarray.c
Modified: trunk/liblwgeom/ptarray.c
--- trunk/liblwgeom/ptarray.c	2016-06-15 16:01:40 UTC (rev 14951)
+++ trunk/liblwgeom/ptarray.c	2016-06-15 16:28:28 UTC (rev 14952)
@@ -71,14 +71,14 @@
 	POINTARRAY *pa = lwalloc(sizeof(POINTARRAY));
 	pa->serialized_pointlist = NULL;
 	/* Set our dimsionality info on the bitmap */
 	pa->flags = gflags(hasz, hasm, 0);
 	/* We will be allocating a bit of room */
 	pa->npoints = 0;
 	pa->maxpoints = maxpoints;
 	/* Allocate the coordinate array */
 	if ( maxpoints > 0 )
 		pa->serialized_pointlist = lwalloc(maxpoints * ptarray_point_size(pa));
@@ -98,20 +98,20 @@
 	size_t point_size = ptarray_point_size(pa);
 	LWDEBUGF(5,"pa = %p; p = %p; where = %d", pa, p, where);
 	LWDEBUGF(5,"pa->npoints = %d; pa->maxpoints = %d", pa->npoints, pa->maxpoints);
 	if ( FLAGS_GET_READONLY(pa->flags) )
 		lwerror("ptarray_insert_point: called on read-only point array");
 		return LW_FAILURE;
 	/* Error on invalid offset value */
 	if ( where > pa->npoints || where < 0)
 		lwerror("ptarray_insert_point: offset out of range (%d)", where);
 		return LW_FAILURE;
 	/* If we have no storage, let's allocate some */
 	if( pa->maxpoints == 0 || ! pa->serialized_pointlist )
@@ -126,14 +126,14 @@
 		lwerror("npoints (%d) is greated than maxpoints (%d)", pa->npoints, pa->maxpoints);
 		return LW_FAILURE;
 	/* Check if we have enough storage, add more if necessary */
 	if( pa->npoints == pa->maxpoints )
 		pa->maxpoints *= 2;
 		pa->serialized_pointlist = lwrealloc(pa->serialized_pointlist, ptarray_point_size(pa) * pa->maxpoints);
 	/* Make space to insert the new point */
 	if( where < pa->npoints )
@@ -141,14 +141,14 @@
 		memmove(getPoint_internal(pa, where+1), getPoint_internal(pa, where), copy_size);
 		LWDEBUGF(5,"copying %d bytes to start vertex %d from start vertex %d", copy_size, where+1, where);
 	/* We have one more point */
 	++pa->npoints;
 	/* Copy the new point into the gap */
 	ptarray_set_point4d(pa, where, p);
 	LWDEBUGF(5,"copying new point to start vertex %d", point_size, where);
 	return LW_SUCCESS;
@@ -199,7 +199,7 @@
 	npoints = pa2->npoints;
 	if ( ! npoints ) return LW_SUCCESS; /* nothing more to do */
 	if( FLAGS_GET_READONLY(pa1->flags) )
@@ -268,23 +268,23 @@
 		lwerror("ptarray_remove_point: null input");
 		return LW_FAILURE;
 	if ( where >= pa->npoints || where < 0)
 		lwerror("ptarray_remove_point: offset out of range (%d)", where);
 		return LW_FAILURE;
 	/* If the point is any but the last, we need to copy the data back one point */
 	if( where < pa->npoints - 1 )
 		memmove(getPoint_internal(pa, where), getPoint_internal(pa, where+1), ptsize * (pa->npoints - where - 1));
 	/* We have one less point */
 	pa->npoints--;
 	return LW_SUCCESS;
@@ -332,7 +332,7 @@
 	if(pa)
 		if(pa->serialized_pointlist && ( ! FLAGS_GET_READONLY(pa->flags) ) )
-			lwfree(pa->serialized_pointlist);
+			lwfree(pa->serialized_pointlist);
 		lwfree(pa);
 		LWDEBUG(5,"Freeing a PointArray");
@@ -431,7 +431,7 @@
 	/* Initial storage */
 	opa = ptarray_construct_empty(hasz, hasm, ipa->npoints);
 	/* Add first point */
 	getPoint4d_p(ipa, ipoff, &p1);
 	ptarray_append_point(opa, &p1, LW_FALSE);
@@ -488,7 +488,7 @@
 	if ( FLAGS_GET_ZM(pa1->flags) != FLAGS_GET_ZM(pa2->flags) ) return LW_FALSE;
 	LWDEBUG(5,"dimensions are the same");
 	if ( pa1->npoints != pa2->npoints ) return LW_FALSE;
 	LWDEBUG(5,"npoints are the same");
@@ -728,21 +728,21 @@
 	seg2 = getPoint2d_cp(pa, pa->npoints-1);
 	if ( check_closed && ! p2d_same(seg1, seg2) )
 		lwerror("ptarray_contains_point called on unclosed ring");
 	for ( i=1; i < pa->npoints; i++ )
 		seg2 = getPoint2d_cp(pa, i);
 		/* Zero length segments are ignored. */
 		if ( seg1->x == seg2->x && seg1->y == seg2->y )
 			seg1 = seg2;
 			continue;
 		ymin = FP_MIN(seg1->y, seg2->y);
 		ymax = FP_MAX(seg1->y, seg2->y);
 		/* Only test segments in our vertical range */
 		if ( pt->y > ymax || pt->y < ymin )
@@ -770,7 +770,7 @@
 			wn++;
 		* If the point is to the right of the line, and it's falling,
 		* then the line is to the right of the point and circling
@@ -780,7 +780,7 @@
 			wn--;
 		seg1 = seg2;
@@ -793,7 +793,7 @@
 		return LW_OUTSIDE;
 	/* Inside */
 	return LW_INSIDE;
@@ -851,11 +851,11 @@
 		double radius, d;
 		POINT2D c;
 		seg2 = getPoint2d_cp(pa, 1);
 		/* Wait, it's just a point, so it can't contain anything */
 		if ( lw_arc_is_pt(seg1, seg2, seg3) )
 			return LW_OUTSIDE;
 		/* See if the point is within the circle radius */
 		radius = lw_arc_center(seg1, seg2, seg3, &c);
 		d = distance2d_pt_pt(pt, &c);
@@ -877,18 +877,18 @@
 		seg3 = getPoint2d_cp(pa, i+1);
 		/* Catch an easy boundary case */
 		if( p2d_same(seg3, pt) )
 			return LW_BOUNDARY;
 		/* Skip arcs that have no size */
 			seg1 = seg3;
 			continue;
 		lw_arc_calculate_gbox_cartesian_2d(seg1, seg2, seg3, &gbox);
 		if ( pt->y > gbox.ymax || pt->y < gbox.ymin )
@@ -903,16 +903,16 @@
 			seg1 = seg3;
 			continue;
 		side = lw_arc_side(seg1, seg2, seg3, pt);
 		/* On the boundary */
 		if ( (side == 0) && lw_pt_in_arc(pt, seg1, seg2, seg3) )
 			return LW_BOUNDARY;
 		/* Going "up"! Point to left of arc. */
 		if ( side < 0 && (seg1->y <= pt->y) && (pt->y < seg3->y) )
@@ -924,7 +924,7 @@
 			wn--;
 		/* Inside the arc! */
 		if ( pt->x <= gbox.xmax && pt->x >= gbox.xmin )
@@ -935,7 +935,7 @@
 			/* On the boundary! */
 			if ( d == radius )
 				return LW_BOUNDARY;
 			/* Within the arc! */
 			if ( d  < radius )
@@ -960,7 +960,7 @@
 		return LW_OUTSIDE;
 	/* Inside */
 	return LW_INSIDE;
@@ -979,10 +979,10 @@
 	double sum = 0.0;
 	double x0, x, y1, y2;
 	int i;
 	if (! pa || pa->npoints < 3 )
 		return 0.0;
 	P1 = getPoint2d_cp(pa, 0);
 	P2 = getPoint2d_cp(pa, 1);
 	x0 = P1->x;
@@ -993,12 +993,12 @@
 		y1 = P3->y;
 		y2 = P1->y;
 		sum += x * (y2-y1);
 		/* Move forwards! */
 		P1 = P2;
 		P2 = P3;
-	return sum / 2.0;
+	return sum / 2.0;
 int
@@ -1019,7 +1019,7 @@
 	int in_hasm = FLAGS_GET_M(pa->flags);
 	POINT4D pt;
 	POINTARRAY *pa_out = ptarray_construct_empty(hasz, hasm, pa->npoints);
 	for( i = 0; i < pa->npoints; i++ )
 		getPoint4d_p(pa, i, &pt);
@@ -1291,11 +1291,11 @@
 	/* Initialize our 2D copy of the input parameter */
 	p.x = p4d->x;
 	p.y = p4d->y;
 	if ( ! proj4d ) proj4d = &projtmp;
 	start = getPoint2d_cp(pa, 0);
 	/* If the pointarray has only one point, the nearest point is */
 	/* just that point */
 	if ( pa->npoints == 1 )
@@ -1305,7 +1305,7 @@
 			*mindistout = distance2d_pt_pt(&p, start);
 		return 0.0;
 	/* Loop through pointarray looking for nearest segment */
 	for (t=1; t<pa->npoints; t++)
@@ -1340,7 +1340,7 @@
 	getPoint4d_p(pa, seg, &start4d);
 	getPoint4d_p(pa, seg+1, &end4d);
 	closest_point_on_segment(p4d, &start4d, &end4d, proj4d);
 	/* Copy 4D values into 2D holder */
 	proj.x = proj4d->x;
 	proj.y = proj4d->y;
@@ -1574,7 +1574,7 @@
 			getPoint4d_p(inpts, stack[sp], &pt);
 			LWDEBUGF(4, "npoints , minpoints %d %d", outpts->npoints, minpts);
 			ptarray_append_point(outpts, &pt, LW_FALSE);
 			LWDEBUGF(4, "Added P%d to simplified point array (size: %d)", stack[sp], outpts->npoints);
 			p1 = stack[sp--];
@@ -1606,7 +1606,7 @@
         lwerror("arc point array with even number of points");
 	a1 = getPoint2d_cp(pts, 0);
 	for ( i=2; i < pts->npoints; i += 2 )
     	a2 = getPoint2d_cp(pts, i-1);
@@ -1631,14 +1631,14 @@
 	if ( pts->npoints < 2 ) return 0.0;
 	frm = getPoint2d_cp(pts, 0);
 	for ( i=1; i < pts->npoints; i++ )
 		to = getPoint2d_cp(pts, i);
 		dist += sqrt( ((frm->x - to->x)*(frm->x - to->x))  +
 		              ((frm->y - to->y)*(frm->y - to->y)) );
 		frm = to;
 	return dist;
@@ -1693,7 +1693,7 @@
 		lwerror("getPoint got NULL pointarray");
 		return NULL;
 	LWDEBUGF(5, "(n=%d, pa.npoints=%d, pa.maxpoints=%d)",n,pa->npoints,pa->maxpoints);
 	if ( ( n < 0 ) ||
@@ -1706,7 +1706,7 @@
 #endif
 	ptr = pa->serialized_pointlist + size * n;
 	if ( FLAGS_NDIMS(pa->flags) == 2)
