[postgis-tickets] r14962 - Shorten ST_ShiftLongitude refpurpose section
Sandro Santilli strk at kbt.io
Thu Jun 16 02:18:36 PDT 2016
Author: strk
Date: 2016-06-16 02:18:36 -0700 (Thu, 16 Jun 2016)
New Revision: 14962
   trunk/doc/reference_processing.xml
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml	2016-06-16 09:09:26 UTC (rev 14961)
+++ trunk/doc/reference_processing.xml	2016-06-16 09:18:36 UTC (rev 14962)
@@ -2645,10 +2645,7 @@
 	  <refnamediv>
 		<refname>ST_ShiftLongitude</refname>
-		<refpurpose>Reads every point/vertex in every component of every feature
-			in a geometry, and if the longitude coordinate is <0, adds 360
-			to it. The result would be a 0-360 version of the data to be
-			plotted in a 180 centric map</refpurpose>
+		<refpurpose>Toggle geometry coordinates between -180..180 and 0..360 ranges.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
