[postgis-tickets] [PostGIS] #3579: Backend crash with mixed collections
PostGIS trac at osgeo.org
Thu Jun 16 05:32:26 PDT 2016
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.2.3
 Component:  postgis  |    Version:  2.2.x
Resolution:  fixed    |   Keywords:
Comment (by pramsey):
 Here's a stack-trace. Seems like a pretty common code path
 (geometry.intersects()). Is it possible we never exercised GEOS w/
 collections containing a mixture of full/empty geometry before?
 * thread #1: tid = 0x1a7a62, 0x000000010be7a09b
 libgeos-3.6.0dev.dylib`geos::algorithm::PointLocator::locate(geos::geom::Coordinate
 const&, geos::geom::LineString const*) [inlined]
 geos::geom::Coordinate::equals2D(this=<unavailable>,
 other=0x0000000000000000) const + 5 at Coordinate.inl:52, queue =
 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1,
 address=0x0)
     frame #0: 0x000000010be7a09b
    49   INLINE bool
    50   Coordinate::equals2D(const Coordinate& other) const
    51   {
 -> 52           if (x != other.x) return false;
    53           if (y != other.y) return false;
    54           return true;
    55   }
 (lldb) bt
 address=0x0)
   * frame #0: 0x000000010be7a09b
     frame #1: 0x000000010be7a096
 geos::geom::operator==(b=0x0000000000000000) at Coordinate.inl:123
     frame #2: 0x000000010be7a096
 libgeos-3.6.0dev.dylib`geos::algorithm::PointLocator::locate(this=<unavailable>,
 p=0x00007f9881e022e0, l=<unavailable>) + 54 at PointLocator.cpp:133
     frame #3: 0x000000010be7a412
 libgeos-3.6.0dev.dylib`geos::algorithm::PointLocator::computeLocation(this=0x00007fff5dba46f0,
 p=0x00007f9881e022e0, geom=<unavailable>) + 418 at PointLocator.cpp:82
     frame #4: 0x000000010be7a026
 libgeos-3.6.0dev.dylib`geos::algorithm::PointLocator::locate(this=0x00007fff5dba46f0,
 p=0x00007f9881e022e0, geom=0x00007f9881e01520) + 182 at
 PointLocator.cpp:55
     frame #5: 0x000000010bef71f4
 libgeos-3.6.0dev.dylib`geos::operation::relate::RelateComputer::labelIsolatedNodes()
 [inlined]
 geos::operation::relate::RelateComputer::labelIsolatedNode(targetIndex=1)
 + 31 at RelateComputer.cpp:508
     frame #6: 0x000000010bef71d5
 libgeos-3.6.0dev.dylib`geos::operation::relate::RelateComputer::labelIsolatedNodes(this=0x00007fff5dba4678)
 + 165 at RelateComputer.cpp:499
     frame #7: 0x000000010bef69c6
 libgeos-3.6.0dev.dylib`geos::operation::relate::RelateComputer::computeIM(this=0x00007fff5dba4678)
 + 374 at RelateComputer.cpp:162
     frame #8: 0x000000010bef8276
 libgeos-3.6.0dev.dylib`geos::operation::relate::RelateOp::relate(geos::geom::Geometry
 const*, geos::geom::Geometry const*) [inlined]
 geos::operation::relate::RelateOp::getIntersectionMatrix() + 8 at
 RelateOp.cpp:74
     frame #9: 0x000000010bef826e
 libgeos-3.6.0dev.dylib`geos::operation::relate::RelateOp::relate(a=<unavailable>,
 b=<unavailable>) + 78 at RelateOp.cpp:42
     frame #10: 0x000000010be83b0d
 libgeos-3.6.0dev.dylib`geos::geom::Geometry::intersects(this=0x00007f9881e017f0,
 g=0x00007f9881e01520) const + 333 at Geometry.cpp:344
     frame #11: 0x000000010306d0b5
 libgeos_c.1.dylib`::GEOSIntersects_r(extHandle=<unavailable>,
 g1=<unavailable>, g2=<unavailable>) + 53 at geos_ts_c.cpp:500
     frame #12: 0x0000000102f6682c
 postgis-2.3.so`geos_intersects(fcinfo=0x00007f98830648a8) + 1628 at
 lwgeom_geos.c:2418
     frame #13: 0x0000000102f69738
 postgis-2.3.so`intersects(fcinfo=0x00007f98830648a8) + 40 at
 lwgeom_backend_api.c:173
     frame #14: 0x00000001022bb29a
 postgres`ExecMakeFunctionResultNoSets(fcache=0x00007f9883064838,
 econtext=0x00007f988305b580, isNull="", isDone=0x0000000000000000) + 346
 at execQual.c:2026
     frame #15: 0x00000001022b4d47
 postgres`ExecEvalFunc(fcache=0x00007f9883064838,
 econtext=0x00007f988305b580, isNull="", isDone=0x0000000000000000) + 199
 at execQual.c:2417
     frame #16: 0x00000001022b5d16
 postgres`ExecEvalAnd(andExpr=0x00007f988305b678,
 econtext=0x00007f988305b580, isNull="", isDone=0x00007f98830689c0) + 134
 at execQual.c:2831
     frame #17: 0x00000001022ba0ef
 postgres`ExecTargetList(targetlist=0x00007f9883068960,
 econtext=0x00007f988305b580, values=0x00007f9883068820, isnull="",
 itemIsDone=0x00007f98830689c0, isDone=0x00007fff5dba4c84) + 175 at
 execQual.c:5307
     frame #18: 0x00000001022ba005
 postgres`ExecProject(projInfo=0x00007f9883068868,
 isDone=0x00007fff5dba4c84) + 741 at execQual.c:5522
     frame #19: 0x00000001022d8084
 postgres`ExecNestLoop(node=0x00007f988305b468) + 1140 at
 nodeNestloop.c:267
     frame #20: 0x00000001022adeaa
 postgres`ExecProcNode(node=0x00007f988305b468) + 490 at execProcnode.c:449
     frame #21: 0x00000001022a98d3
 postgres`ExecutePlan(estate=0x00007f9883056438,
 planstate=0x00007f988305b468, operation=CMD_SELECT, sendTuples='\x01',
 numberTuples=0, direction=ForwardScanDirection, dest=0x00007f988304ac40) +
 115 at execMain.c:1490
     frame #22: 0x00000001022a97fa
 postgres`standard_ExecutorRun(queryDesc=0x00007f988302aa38,
 direction=ForwardScanDirection, count=0) + 490 at execMain.c:319
     frame #23: 0x00000001022a960a
 postgres`ExecutorRun(queryDesc=0x00007f988302aa38,
 direction=ForwardScanDirection, count=0) + 74 at execMain.c:267
     frame #24: 0x00000001024676a4
 postgres`PortalRunSelect(portal=0x00007f9883044438, forward='\x01',
 count=0, dest=0x00007f988304ac40) + 308 at pquery.c:942
     frame #25: 0x0000000102467087
 postgres`PortalRun(portal=0x00007f9883044438, count=9223372036854775807,
 isTopLevel='\x01', dest=0x00007f988304ac40, altdest=0x00007f988304ac40,
 completionTag="") + 679 at pquery.c:786
     frame #26: 0x0000000102462947
 postgres`exec_simple_query(query_string="with\n        params as (\n
 select\n            11 :: float as sidewalk_offset,\n            1 ::
 float  as epsilon\n    ),\n        road as (\n\n        select
 'SRID=3857;LINESTRING(10 0, 0 0, 0 10)' :: geometry as geom\n    ),\n
 sidewalks as (\n        select ST_Collect(\n
 ST_OffsetCurve(geom, sidewalk_offset),\n
 ST_OffsetCurve(geom, -sidewalk_offset)\n               ) geom\n
 from road, params\n    )\nselect\n    ST_Intersects(road.geom,
 sidewalks.geom),\n\n    ST_Intersects(ST_Buffer(road.geom, sidewalk_offset
 + epsilon), sidewalks.geom) \nfrom road, sidewalks, params;") + 1239 at
 postgres.c:1072
     frame #27: 0x0000000102461cb8 postgres`PostgresMain(argc=1,
 argv=0x00007f98820060d8, dbname="postgis23", username="pramsey") + 2856 at
 postgres.c:4079
     frame #28: 0x00000001023ca585
 postgres`BackendRun(port=0x00007f9881f00c80) + 693 at postmaster.c:4285
     frame #29: 0x00000001023c97c8
 postgres`BackendStartup(port=0x00007f9881f00c80) + 408 at
 postmaster.c:3948
     frame #30: 0x00000001023c8985 postgres`ServerLoop + 597 at
 postmaster.c:1679
     frame #31: 0x00000001023c6271 postgres`PostmasterMain(argc=3,
 argv=0x00007f9881c07220) + 5409 at postmaster.c:1287
     frame #32: 0x0000000102305daa postgres`main(argc=3,
 argv=0x00007f9881c07220) + 746 at main.c:233
     frame #33: 0x00007fff8454b5ad libdyld.dylib`start + 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3579#comment:8>
