[postgis-tickets] [PostGIS] #3579: Backend crash with mixed collections
PostGIS trac at osgeo.org
Thu Jun 16 06:02:38 PDT 2016
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.2.3
 Component:  postgis  |    Version:  2.2.x
Resolution:  fixed    |   Keywords:
Comment (by pramsey):
 Based on the example provided, here's the minimal crasher, which could be
 tested in GEOS.
  select st_intersects(
  'LINESTRING(10 0, 0 0, 0 10)'::geometry,
  'MULTILINESTRING((10 -1,-1 10),EMPTY)'::geometry
 Just having the collection-with-empty structure was not enough to induce a
 crash, the geometries had to overlap so that the overlay code was started
 up. Then things went boom.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3579#comment:10>
