[postgis-tickets] [PostGIS] #3583: Server crashes when running particular ST_GeomFromJSON command
PostGIS trac at osgeo.org
Fri Jun 17 15:00:41 PDT 2016
 Reporter:  bmmpxf   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.1.9
Component:  postgis  |    Version:  2.1.x
 Keywords:           |
 Hi. In pgAdmin (or psql), running the following command:
 Select ST_GeomFromGeoJSON('{"type":"MultiPolygon",
 "coordinates":[[[139.10030364990232,35.16777444430609],5842.4224490305424]]}');
 The Postgres service immediately shuts down. I've never seen this sudden
 behavior before.
 Log file shows:
 LOG:  server process (PID 9576) was terminated by exception 0xC0000005
 DETAIL:  Failed process was running: select
 HINT:  See C include file "ntstatus.h" for a description of the
 hexadecimal value.
 According to Microsoft, exception 0xC0000005 means
 "STATUS_ACCESS_VIOLATION": "The instruction at 0x%08lx referenced memory
 at 0x%08lx. The memory could not be %s."
 https://msdn.microsoft.com/en-us/library/cc704588.aspx
 Tested on PostGIS 2.1.7 and Postgres 9.3 on Windows 10 and Windows Server
 2012.
 Any ideas?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3583>
