[postgis-tickets] r14971 - Add test for #3583
Paul Ramsey pramsey at cleverelephant.ca
Fri Jun 17 15:22:41 PDT 2016
Author: pramsey
Date: 2016-06-17 15:22:40 -0700 (Fri, 17 Jun 2016)
New Revision: 14971
   trunk/regress/tickets.sql
   trunk/regress/tickets_expected
Add test for #3583
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql	2016-06-17 22:19:49 UTC (rev 14970)
+++ trunk/regress/tickets.sql	2016-06-17 22:22:40 UTC (rev 14971)
@@ -990,5 +990,9 @@
     ST_Intersects(ST_Buffer(road.geom, sidewalk_offset + epsilon), sidewalks.geom) -- should be true
 from road, sidewalks, params;
+-- #3583
+Select '#3583', ST_AsText(ST_GeomFromGeoJSON('{"type":"MultiPolygon", "coordinates":[[[139.10030364990232,35.16777444430609],5842.4224490305424]]}'));
 -- Clean up
 DELETE FROM spatial_ref_sys;
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected	2016-06-17 22:19:49 UTC (rev 14970)
+++ trunk/regress/tickets_expected	2016-06-17 22:22:40 UTC (rev 14971)
@@ -295,3 +295,4 @@
 #3470|t
 #3470b|50
 #3579|f|t
+#3583|MULTIPOLYGON Z (EMPTY)
