[postgis-tickets] [PostGIS] #3586: Error in Manual - faq_raster.xml.pot
PostGIS trac at osgeo.org
Mon Jun 20 21:37:44 PDT 2016
 Reporter:  ruvyn                    |      Owner:  pramsey
     Type:  patch                    |     Status:  new
 Priority:  low                      |  Milestone:  PostGIS 2.3.0
Component:  postgis                  |    Version:  trunk
 Keywords:  PostGIS 2.3.0dev Manual  |
 In answer about 'function is not unique',
 "The function is not unique error happens if one of your arguments is a
 textual representation of a geometry instead of a geometry. In these
 cases, PostgreSQL marks the textual representation as an unknown type,
 which means it can fall into the st_intersects(raster, geometry) or
 st_intersects(raster,raster) thus resulting in a non-unique case since
 both functions can in theory support your request. To prevent this, you
 need to cast the geometry to a geometry."
 I think the last sentence should be like:
 "To prevent this, you need to cast the textual representation of geometry
 to a geometry."
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3586>
