[postgis-tickets] [PostGIS] #3589: Error in Manual - extras_topology.xml.pot
PostGIS trac at osgeo.org
Thu Jun 23 23:13:02 PDT 2016
 Reporter:  ruvyn                    |      Owner:  robe
     Type:  patch                    |     Status:  new
 Priority:  low                      |  Milestone:  PostGIS 2.3.0
Component:  documentation            |    Version:  trunk
 Keywords:  PostGIS 2.3.0dev Manual  |
 1. ST_ChangeEdgeGeom
 "If any arguments are null, the given edge does not exist in the
 <varname>node</varname> table of the topology schema, ..."
 <varname>node</varname> -> <varname>edge</varname>
 2. ST_RemoveIsoNode
 "-- Add an isolated node with no face --"
 Add -> Remove
 3. AsTopoJSON
 "Arc indices in the TopoJSONjoutput are 0-based but they are 1-based in
 the "edgeMapTable" table."
 TopoJSONjoutput -> TopoJSON output
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3589>
