[postgis-tickets] [PostGIS] #3592: Error in Manual - extras_address_standardizer.xml.pot
PostGIS trac at osgeo.org
Sun Jun 26 19:46:17 PDT 2016
 Reporter:  ruvyn                    |      Owner:  robe
     Type:  patch                    |     Status:  new
 Priority:  low                      |  Milestone:  PostGIS 2.3.0
Component:  documentation            |    Version:  trunk
 Keywords:  PostGIS 2.3.0dev Manual  |
 1. in 'ruralroute' of 12.2. Address Standardizer Types
 "is text (token number 8): RURAL ROUTE . Example 8 in RR 7."
 "Example 8 in RR 7." -> "Example: 7 in RR 7."
 2. in 'EXTRA_C output tokens' of 12.3. Address Standardizer Tables
 "i(token number <code>14</code>): The <emphasis role="bold">BOX</emphasis>
 in <code>BOX 3B</code>"
 i(token number <code>14</code>): -> (token number <code>14</code>):
 3. in 'gaz table' of 12.3. Address Standardizer Tables
 "A gaz (short for gazeteer) table is used to classify place names and
 classify -> standardize
 4. in 'parse_address' of 12.4. Address Standardizer Functions
 "Returns takes as input an address, and ..."
 -> Takes an address as input, and...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3592>
