[postgis-tickets] [PostGIS] #3593: Error in Manual - extras_tigergeocoder.xml.pot
PostGIS trac at osgeo.org
Tue Jun 28 04:28:54 PDT 2016
 Reporter:  ruvyn                    |      Owner:  robe
     Type:  patch                    |     Status:  new
 Priority:  low                      |  Milestone:  PostGIS 2.3.0
Component:  documentation            |    Version:  trunk
 Keywords:  PostGIS 2.3.0dev Manual  |
 1. in Abstract
 "For instructions on how enable the extension in your database and also to
 load data using it, refer to Refer to ..."
 refer to Refer to -> refer to
 2. in Abstract
 "... that the county and <varname>county</varname> and
 <varname>state</varname> tables are no longer ..."
 -> that <varname>county</varname> and <varname>state</varname> tables are
 no longer
 3. in Abstract
 "<ulink
 url="http://wiki.openstreetmap.org/wiki/Nominatim">Nominatim</ulink> and
 uses ..."
 -> <ulink
 url="http://wiki.openstreetmap.org/wiki/Nominatim">Nominatim</ulink> uses
 4. in Drop_Nation_Tables_Generate_Script
 "... or stae code followed by ..."
 stae -> state
 5. in Geocode
 "New parameter max_results useful for specifying ot just return the best
 result."
 -> New parameter max_results is useful for specifying or just returning
 the best result.
 6. in Geocode_Intersection
 "Takes in 2 streets that intersect and a state, city, zip, and outputs a
 set of possible locations on the first cross street that is at the
 intersection, also includes a point geometry in NAD 83 long lat, a
 normalized address for each location, and the rating. The lower the rating
 the more likely the match. Results are sorted by lowest rating first. Can
 optionally pass in maximum results, defaults to 10. Returns
 <varname>normalized_address</varname> (addy) for each, geomout as the
 point location in nad 83 long lat, and the rating. The lower the rating
 the more likely the match. Results are sorted by lowest rating first. Uses
 Tiger data (edges,faces,addr), PostgreSQL fuzzy string matching
 (soundex,levenshtein)"
 -> Takes in 2 streets that intersect and a state, city, zip, and outputs a
 intersection, also includes a geomout as the point location in NAD 83 long
 lat, a <varname>normalized_address</varname> (addy) for each location, and
 the rating. The lower the rating the more likely the match. Results are
 sorted by lowest rating first. Can optionally pass in maximum results,
 defaults to 10. Uses Tiger data (edges, faces, addr), PostgreSQL fuzzy
 string matching (soundex, levenshtein).
 7. in Get_Geocode_Setting
 "Use customized settingsa re in ..."
 -> Use customized settings are in
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3593>
