[postgis-tickets] [PostGIS] #3444: Add dump/restore testing
PostGIS trac at osgeo.org
Tue Mar 1 02:19:04 PST 2016
  Reporter:  strk         |      Owner:  robe
      Type:  enhancement  |     Status:  reopened
  Priority:  medium       |  Milestone:  PostGIS 2.3.0
 Component:  buildbots    |    Version:  2.2.x
Resolution:               |   Keywords:
Comment (by strk):
 Regina check the travis side (PR above), you'll notice --dumprestore is
 used both with "make check" _and_ with "make installcheck". The former
 tests _scripts_, the latter tests _extension_.
 Only the "installcheck" rule (with extension) needs a previous "install"
 and is affected by it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3444#comment:29>
