[postgis-tickets] [PostGIS] #3460: Upgrade to 2.2 doesn't adjust size of pgis_abs type
PostGIS trac at osgeo.org
Tue Mar 1 02:21:43 PST 2016
  Reporter:  dbaston  |      Owner:  dbaston
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Comment (by strk):
 The upgrade script considers Major.Minor versions, no Patch version.
 As long as the "Availability" label is present in the .sql script source,
 it should be adding the appropriate CREATE TYPE, see
 https://trac.osgeo.org/postgis/browser/tags/2.2.1/utils/postgis_proc_upgrade.pl#L101
 and
 https://trac.osgeo.org/postgis/browser/tags/2.2.1/utils/postgis_proc_upgrade.pl#L252
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3460#comment:3>
