[postgis-tickets] [PostGIS] #3485: ST_ClusterKMeans garden crash - not empty geometry safe
PostGIS trac at osgeo.org
Tue Mar 1 15:56:52 PST 2016
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.3.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 SELECT ST_ClusterKMeans(foo1.the_geom, 3)OVER()  As result
                                                         FROM ((SELECT
 ST_GeomFromText('POINT EMPTY',4326) As the_geom
                         UNION ALL SELECT ST_GeomFromText('MULTIPOINT
                         UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON
                         UNION ALL SELECT ST_GeomFromText('LINESTRING
                         UNION ALL SELECT ST_GeomFromText('MULTILINESTRING
 EMPTY',4326) As the_geom ) ) As foo1 LIMIT 3;
 Do this and server hits the sac.
 Simplified also crashes
 SELECT ST_ClusterKMeans(foo1.the_geom, 1)OVER()  As result
         FROM (SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom) As
 foo1;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3485>
