[postgis-tickets] [PostGIS] #3165: make_dist.sh should allow for custom configure
PostGIS trac at osgeo.org
Tue Mar 1 17:36:42 PST 2016
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS Future
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by gdt):
 I am having the same problem, and the first symptom is not finding proj.
 This could be worked around by having proj looked for in the search path;
 I do pass in CPPFLAGS/LDFLAGS in the environment.  But that won't solve
 the general issues.
 I wonder if the configure options used to build postgis can be extracted
 from config.status and then used.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3165#comment:1>
