[postgis-tickets] [PostGIS] #3488: make_dist.sh uses non-POSIX "mv -T"
PostGIS trac at osgeo.org
Thu Mar 3 00:41:00 PST 2016
  Reporter:  gdt                    |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS Future
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 -T does not remove the old directory, but simply refuses to consider
 it a target directory in which to _move_ things:
   -T, --no-target-directory
       treat DEST as a normal file
 If the directory exists, it would fail.
 But then we add --backup=t, which renames the target directory,
 if existing. Finding a name which is available, from a pattern.
 Anyway, simplified the code by forcing removal of target dir
 with r14737. Once happy this will need to be copied over
 the 2.2 branch.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3488#comment:5>
