[postgis-tickets] [PostGIS] #3490: Create perl script to add in the ALTER FUNCTION set path calls
PostGIS trac at osgeo.org
Fri Mar 4 18:15:14 PST 2016
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.2
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> As discussed in several tickets.
> PostGIS functions that call postgis functions fail when the schema that
> postgis is installed in is not in the search_path.
> The generated script will look something like this -
> https://trac.osgeo.org/postgis/browser/trunk/postgis/postgis_functions_search_path.sql
> for will have all functions
> Such a scenario happens in the following cases:
> 1. During database restore - raster constraints rely on functions that
> call other functions, and as a result data does not come back if your
> data is not in the same schema as where postgis is installed
> 2. Restore of spatial indexes that use ST_Transform, again if your data
> is not in same schema as postgis.
> 3. Materialized views restore - views that use ST_Intersects etc. may not
> come back.  So this is fairly serious. Again if not in same schema as
> postgis
> 4. Foreign Tables.  The Foreign tables as I recall are set to ignore
> search_path so a foregin table calling ST_Intersects etc will fail if the
> table is not in the same schema as where PostGIS is installed.
> I'm working on a perl script to set the search_path setting of all
> functions.  I plan to distribute this as part of PostGIS 2.2 (not as part
> of extension install).  With an FAQ in the docs that people suffering
> from this issue need to
> 1) Install postgis first
> 2) Run this script
> 3) then restore their data
> For PostGIS 2.3, I'd like to just include this as part of the CREATE
> EXTENSION install so I don't have to explain this to anybody ever again.
> At least 5 people have complained to me about this already and I have
> suffered from it myself.  Enough is enough.
New description:
 call other functions, and as a result data does not come back if your data
 2. Restore of spatial indexes that use ST_Transform, again if your data is
 postgis
 of extension install).  With an FAQ in the docs that people suffering from
 this issue need to
 2) Run this script
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3490#comment:5>
