[postgis-tickets] [PostGIS] #3491: ST_GeneratePoints regress needs an order by
PostGIS trac at osgeo.org
Fri Mar 4 19:15:05 PST 2016
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.3.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 I think the ST_GeneratePoints needs an ORDER BY clause to ensure order
 consistency across all platforms.
 Just ran and got this:
              tickets .. failed (diff expected obtained:
 /projects/postgis/tmp/2.3_pg9.5w64/test_87_diff)
 --- tickets_expected    2016-02-26 18:57:58 -0500
 +++ /projects/postgis/tmp/2.3_pg9.5w64/test_87_out      2016-03-04
 22:05:24 -0500
 @@ -278,9 +278,9 @@
  #3367|POLYGON EMPTY
 #3368|\x660001011fb98788d35ed6fbcdc831c580012b959f01469d8d0e9305ff8618ed08b1b607e302a614fe70bc4682b303b4379ab503a228eeb603e2138eb802900cc0b802ba04dab802b801a8840cb0229cca06f401c216f403a016ea05d0c301a8b301cc189226ac15ee27f811a029b40eac2ae00a902b8407c82b9e03d0e305801dfad3239504ce7e8d01e2f701f6019b04d1e2279bf901ff01
  #3375|GEOMETRYCOLLECTION(POINT(0 -7))
 +#3399|1000|1000
  #3399|1|1
  #3399|10|10
 -#3399|1000|1000
  #3399|100|100
  ERROR:  invalid KML representation
  #3437a|5
 It's quite possible I'm seeing this because I was testing my search path
 patch.  Anyrate looking at the test, it's not deterministic.
 -- #3399
 WITH g as (
 select 'POLYGON((1 0, 0 1, 1 2, 2 1, 1 0))'::geometry as geom
 n as (
 select n from unnest(ARRAY[-1,0,1,10,100,1000]) n
 pts as (
   select n,(st_dump(st_generatepoints(geom, n))).geom from g,n
 select '#3399' as t, n, count(*) from
 g, pts
 where st_contains(g.geom, pts.geom)
 group by n;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3491>
