[postgis-tickets] [PostGIS] #3486: function st_within - e
PostGIS trac at osgeo.org
Fri Mar 4 21:50:33 PST 2016
  Reporter:  giau81   |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:  st_within,st_Contains, search_path
Changes (by robe):
 * milestone:  PostGIS 2.2.2 => PostGIS 2.3.0
Comment:
 Sadly this will not be fixed by #3490 which will fix others.
 My plan to put search_path on all functions can't be done on functions
 that rely on SQL Inlining to to use spatial index.  Putting ALTER FUNCTION
 .. search_path on these destroys the inlining behavior.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3486#comment:3>
