[postgis-tickets] r14751 - remove this hard-coded script superceded by perl generation script of #3490
Regina Obe lr at pcorp.us
Fri Mar 4 22:01:03 PST 2016
Author: robe
Date: 2016-03-04 22:01:03 -0800 (Fri, 04 Mar 2016)
New Revision: 14751
Removed:
   trunk/postgis/postgis_functions_search_path.sql
References #2485
Deleted: trunk/postgis/postgis_functions_search_path.sql
--- trunk/postgis/postgis_functions_search_path.sql	2016-03-05 05:37:31 UTC (rev 14750)
+++ trunk/postgis/postgis_functions_search_path.sql	2016-03-05 06:01:03 UTC (rev 14751)
@@ -1,44 +0,0 @@
--- PostGIS - Spatial Types for PostgreSQL
--- http://postgis.net
--- Copyright 2016 Regina Obe
--- This is free software; you can redistribute and/or modify it under
--- the terms of the GNU General Public Licence. See the COPYING file.
--- This routine adds search_path to functions known to have issues
--- during restore.  Functions that call other postgis functions
--- or spatial_ref_sys should be in here
--- These are functions that are called by restore process for purposes of
--- creating indexes, creating constraints, and creating materialized views
--- Also functions that are used in foreign tables
--- that call other postgis functions.  Eventually all functions should be here
--- At that point we decide to add to all functions,
--- this script should be autogenerated
-DO language plpgsql
-DECLARE param_postgis_schema text;
-BEGIN
--- check if PostGIS is already installed
-param_postgis_schema = (SELECT n.nspname from pg_extension e join pg_namespace n on e.extnamespace = n.oid WHERE extname = 'postgis');
--- if in middle install, it will be the current_schema or what was there already
-param_postgis_schema = COALESCE(param_postgis_schema, current_schema());
-EXECUTE 'set search_path TO ' || quote_ident(param_postgis_schema);
--- PostGIS geometry funcs
-EXECUTE 'ALTER FUNCTION st_transform(geometry, integer) SET search_path=' || quote_ident(param_postgis_schema) || ';';
--- PostGIS raster funcs
-EXECUTE 'ALTER FUNCTION _raster_constraint_nodata_values(raster) SET search_path=' || quote_ident(param_postgis_schema) || ';';
-EXECUTE 'ALTER FUNCTION _raster_constraint_out_db(raster) SET search_path=' || quote_ident(param_postgis_schema) || ';';
-EXECUTE 'ALTER FUNCTION _raster_constraint_pixel_types(raster) SET search_path=' || quote_ident(param_postgis_schema) || ';';
-END;
