[postgis-tickets] [PostGIS] #3460: Upgrade to 2.2 doesn't adjust size of pgis_abs type
PostGIS trac at osgeo.org
Sat Mar 5 01:57:27 PST 2016
  Reporter:  dbaston  |      Owner:  dbaston
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Comment (by strk):
 My only concern is with different postgresql versions possibly
 storing those values in a different way or giving different access
 to update them. As long as it's tested against every supported version
 it's ok with me.
 Do we have a test in place showing how an upgraded database
 (failing to update the size) corrupts the results ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3460#comment:11>
