[postgis-tickets] [PostGIS] #3277: Raster import fails from different schema with constraint
PostGIS trac at osgeo.org
Sat Mar 5 12:04:28 PST 2016
  Reporter:  jczaplewski  |      Owner:  dustymugs
      Type:  defect       |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 2.2.2
 Component:  raster       |    Version:  2.1.x
Resolution:  fixed        |   Keywords:  raster, restore
Comment (by robe):
 Note for 2.2.2 - one would need to run the script explicitly as noted in
 FAQ -
 http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore
 For PostGIS 2.3, this will be automatic and not require script running
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3277#comment:4>
