[postgis-tickets] [PostGIS] #3494: fully-qualified operators/functions - problems during a restore of a logical dump
PostGIS trac at osgeo.org
Tue Mar 8 05:52:29 PST 2016
logical dump
 Reporter:  gbroccolo                            |      Owner:  pramsey
     Type:  enhancement                          |     Status:  new
 Priority:  low                                  |  Milestone:  PostGIS
                                                 |  PostgreSQL
Component:  postgis                              |    Version:  2.2.x
 Keywords:  fully-qualified, operators,          |
  functions                                      |
 I'm wondering about the following case: considering the restore of a
 *logical* dump of a database with the PostGIS extension installed,
 containing tables with some fields with a CHECK constraint that involves
 some PostGIS operators/functions, e.g.
 CREATE TABLE t(
     i integer PRIMARY KEY,
     g geometry CHECK (g && ST_Polygon(ST_GeomFromText('LINESTRING(75.15
 29.53,77 29,77.6 29.5, 75.15 29.53)'), 4326))
 The restore will recreate all PostGIS operators/functions, but not in the
 right schema (postgis), and should raise errors like "ERROR: operator does
 not exist: postgis.geometry && postgis.geometry" in my example, since
 PostGIS operators/functions are not restored where expected.
 The issue could be avoided if the operators and the functions would be
 fully-qualified (i.e. the schema is specified in the DDL during their
 creation). In my example, the workaround was to define the && operator in
 the public schema, where the restore is done.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3494>
