[postgis-tickets] [PostGIS] #3495: AddGeometryColumn relies on table being in search_path
PostGIS trac at osgeo.org
Tue Mar 8 09:17:17 PST 2016
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.2
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Okay discovered an isssue with my search_path setting logic.
> The way our AddGeometryColumn works.  The version that doesn't take
> schema requires the table with geometry column being added has schema
> set.
> I discovered this issue with
> CREATE SCHEMA postgis VERSION "2.3.0dev";
> CREATE EXTENSION postgis SCHEMA postgis;
> ALTER DATABASE workshop_1
>   SET search_path = public, postgis;
> -- and then using shp2pgsql to restore
> shp2pgsql -I -D -s 26986 data/MBTA_ARC mbta_lines | psql
> ALTER TABLE
> ERROR:  Table 'mbta_lines' does not occur in the search_path
> CONTEXT:  SQL statement "SELECT
> AddGeometryColumn('',$1,$2,$3,$4,$5,$6,$7)"
> PL/pgSQL function addgeometrycolumn(character varying,character
> varying,character varying,integer,character varying,integer,boolean) line
> 5 at SQL statement
> ERROR:  current transaction is aborted, commands ignored until end of
> transaction block
> invalid command \.
> ERROR:  syntax error at or near "GREEN"
> LINE 1: GREEN C D 7 4.58386095740e+002 01050000206A69000001000000010...
> ROLLBACK
> ERROR:  relation "mbta_lines" does not exist
> So I guess we've got to exclude all these from my search_path logic I put
> in on #3490. Eventually I think we'll need to force everyone to install
> postgis in same schema and schema qualify at least these ones and
> relationship ones that rely on users schema to be in search path to work
> well.
New description:
 The way our AddGeometryColumn works.  The version that doesn't take schema
 requires the table with geometry column being added has schema set.
 ALTER TABLE
 5 at SQL statement
 transaction block
 invalid command \.
 ROLLBACK
 however this works okay -specifying schema of table
 shp2pgsql -I -D -s 26986 data/MBTA_ARC public.mbta_lines | psql
 well.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3495#comment:1>
