[postgis-tickets] [PostGIS] #3500: winnie 32-bit failing on KMeans Cunit
PostGIS trac at osgeo.org
Thu Mar 10 13:01:28 PST 2016
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 2.3.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 Have no idea why this is happening:
 -------------- Compiler Info -------------
   C compiler:           i686-w64-mingw32-gcc -g -O2
   SQL preprocessor:     /mingw/bin/cpp -traditional-cpp -w -P
  -------------- Dependencies --------------
   GEOS config:          /projects/geos/rel-3.5.0w32gcc481/bin/geos-config
   GEOS version:         3.5.0dev
   GDAL config:          /projects/gdal/rel-2.0.1w32gcc481/bin/gdal-config
   GDAL version:         2.0.1
   SFCGAL config:        /projects/CGAL/rel-sfcgal-1.2w32gcc481/bin/sfcgal-
 config
   SFCGAL version:       1.3.0
   PostgreSQL config:
 /projects/postgresql/rel/pg9.4w32gcc481/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.4.5
   PROJ4 version:        49
   Libxml2 config:       /projects/libxml/rel-
 libxml2-2.7.8w32gcc481/bin/xml2-config
   Libxml2 version:      2.7.8
   JSON-C support:       yes
   PCRE support:         yes
   PostGIS debug level:  0
   Perl:                 /bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       enabled
   PostGIS Topology:     enabled
   SFCGAL support:       enabled
   Address Standardizer support:       enabled
  -------- Documentation Generation --------
   xsltproc:             /projects/xsltproc/xsltproc
   xsl style sheets:     /projects/docbook/docbook-xsl-1.76.1
   dblatex:
   convert:              /c/Windows/system32/convert
   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 Test: test_kmeans ...Makefile:84: recipe for target `check' failed
 make[2]: *** [check] Error 5
 make[2]: Leaving directory
 `/projects/postgis/branches/2.3/liblwgeom/cunit'
 Makefile:204: recipe for target `check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/projects/postgis/branches/2.3/liblwgeom'
 GNUmakefile:16: recipe for target `check' failed
 make: *** [check] Error 1
 Will research later when I have time.  Might only be 32-bit run.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3500>
