[postgis-tickets] [PostGIS] #3483: Problem with ST_Union
PostGIS trac at osgeo.org
Thu Mar 17 01:22:10 PDT 2016
  Reporter:  krzysiek  |      Owner:  dustymugs
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.1.9
 Component:  raster    |    Version:  2.1.x
Resolution:            |   Keywords:  ST_Union, raster, alignment
Comment (by krzysiek):
 A little update on the issue.
 I've been struggling trying to workaround the problem and it seems that
 90% of cases I managed to resolve using ST_MapAlgebraExpr and
 incrementally merging rasters in a loop. It is extremely slow but at least
 I managed to process some of the data (not sure whether it workaround all
 of the problems).
 Another issue (or maybe a clue) I've found processing data obtained from a
 rasterized vector layer using ST_AsRaster. For some of pieces of data
 ST_Union works fine but in some cases fails, below you can find the piece
 of code that is failing due to lack of alignment  :
 with polys as
                select ST_Union(rast,'LAST') as rast from
                select
 ST_Resample(ST_Clip(ST_AsRaster(ST_Intersection(c2d.rect,p_aoi),p_ref_raster,ARRAY['8BUI',
 '8BUI', '8BUI'],
                  case
                     when c2d.value=10 then ARRAY[1,255,1]
                     when c2d.value=20 then ARRAY[255,255,1]
                     when c2d.value=30 then ARRAY[255,127,1]
                     else ARRAY[255,255,255]
                  end
                 , ARRAY[0,0,0]),p_aoi),p_ref_raster) as rast
                from (
                 select *  from
                  classified2d  c2d1
                where c2d1.rect && p_aoi
                 and c2d1.value<>40
                 and c2d1.mean_depth>0) as c2d
                 where
 I've copied problematic data into table rasters.r and tested it using
 following code:
 -- Wykonanie zapytania:
 DO $$
 declare
  l_buffer               raster;
  i integer;
  j integer;
 BEGIN
   FOR i IN 1..192 LOOP
       select ST_Union(rast) into l_buffer from
        (select filename,rast
           from rasters.r
       -- order by filename
        ) as a
          where filename::integer<i;
       RAISE NOTICE '%  % %  ',i,ST_Width(l_buffer),ST_Height(l_buffer);
   end loop;
 END $$;
 The result is as follows:
 UWAGA:  1  <NULL> <NULL>
 UWAGA:  2  73 78
 UWAGA:  3  230 241
 UWAGA:  4  593 586
 UWAGA:  5  1165 1153
 UWAGA:  6  1534 1379
 UWAGA:  7  1534 1379
 UWAGA:  8  1769 2342
 UWAGA:  9  3009 2342
 UWAGA:  10  3009 2374
 UWAGA:  11  4542 3589
 UWAGA:  12  4600 3589
 UWAGA:  13  4600 3589
 UWAGA:  14  4600 3589
 UWAGA:  15  4600 3589
 UWAGA:  16  4600 3589
 UWAGA:  17  4600 3589
 UWAGA:  18  4600 3589
 UWAGA:  19  4600 3589
 BŁĄD:  rt_raster_from_two_rasters: The two rasters provided do not have
 the same alignment
 If I enable sorting :
 DO $$
 declare
  l_buffer               raster;
  i integer;
  j integer;
 BEGIN
           from rasters.r
        order by filename
        ) as a
   end loop;
 END $$;
 Everything works fine (at least for this case):
 UWAGA:  2  73 78
 UWAGA:  3  230 241
 UWAGA:  4  593 586
 UWAGA:  5  1165 1153
 UWAGA:  6  1534 1379
 UWAGA:  7  1534 1379
 UWAGA:  8  1769 2342
 UWAGA:  9  3009 2342
 UWAGA:  10  3009 2374
 UWAGA:  11  4542 3589
 UWAGA:  12  4600 3589
 UWAGA:  13  4600 3589
 UWAGA:  14  4600 3589
 UWAGA:  15  4600 3589
 UWAGA:  16  4600 3589
 UWAGA:  17  4600 3589
 UWAGA:  18  4600 3589
 UWAGA:  19  4600 3589
 UWAGA:  20  4678 3589
 UWAGA:  21  4796 3589
 UWAGA:  177  8337 7601
 UWAGA:  178  8337 7601
 UWAGA:  179  8337 7601
 UWAGA:  180  8337 7601
 UWAGA:  181  8337 7601
 UWAGA:  182  8337 7601
 UWAGA:  183  8337 7601
 UWAGA:  184  8337 7601
 UWAGA:  185  8337 7601
 UWAGA:  186  8337 7601
 UWAGA:  187  8337 7601
 UWAGA:  188  8337 7601
 UWAGA:  189  8337 7601
 UWAGA:  190  8337 7601
 UWAGA:  191  8337 7601
 UWAGA:  192  8337 7601
 Query returned successfully with no result in 05:57 minutes.
 I've been testing it with different data but it didnt' help. From other
 tests I've done (mostly changing the order of the rasters returned by the
 internal query) the impression I have is that the result, for some reason,
 depends on sequence in which the data arrive to ST_Union.
 Are there any chances that somebody will take a look at the issue in near
 future ? Maybe I am doing something particularly wrong  in this code:
 CREATE OR REPLACE FUNCTION get_rasterized_features1(
     p_aoi geometry,            -- area of interest
     p_ref_raster raster)       -- raster that will be background for the
 data returned   by this function
   RETURNS raster AS
 $BODY$
 declare
  l_tmp_classified       raster;
  l_tmp_patches          raster;
  l_tmp_features         raster;
  l_tmp_skeletons         raster;
  l_res       raster;
 begin
 with classified as
                --select rast as rast,classified2d_id  from
                select
 ST_MakeEmptyRaster(ST_AddBand(ST_AddBand(p_ref_raster,p_ref_raster),p_ref_raster))
 as rast, -1 as  classified2d_id
                union all
                --select
 '8BUI', '8BUI'],
               select ST_AsRaster(c2d.rect,p_ref_raster,ARRAY['8BUI',
 '8BUI', '8BUI'],
                  case
                  end
                 , ARRAY[0,0,0]) as rast
                 ,classified2d_id
               from (
                 select *  from
                  classified2d  c2d1
                 and c2d1.value<>40
                 where
                     ST_Intersects(c2d.rect ,p_aoi)
                 and c2d.mean_length>5*c2d.mean_width/1000 and
 ST_Area(rect)>0.00010681
                 order by 2 ) as p
                 where  not ST_IsEmpty(rast)
       --insert into rasters.r  select classified2d_id,rast, 'Brak'::text
 from classified;
       select  ST_Clip(rast,p_aoi) into l_tmp_classified  from classified;
    return l_tmp_classified
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3483#comment:6>
