[postgis-tickets] [PostGIS] #3505: Documented ST_MakeEmptyRaster version does not exist
PostGIS trac at osgeo.org
Fri Mar 18 02:44:59 PDT 2016
 Reporter:  strk     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.3.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 The {{{ ST_MakeEmptyRaster(int,int,float8,float8,float8) }}} function is
 documented here: http://postgis.net/docs/manual-
 dev/RT_ST_MakeEmptyRaster.html
 .. but is not present in rtpostgis.sql of trunk (2.3.0dev).
 Is the manual wrong or the code broken ?
 Why doesn't the automated test catch this ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3505>
