[postgis-tickets] [PostGIS] #3503: ST_ColorMap regress failing on PostgreSQL 9.6 debbie
PostGIS trac at osgeo.org
Sat Mar 12 13:37:03 PST 2016
 Reporter:  robe      |      Owner:  dustymugs
     Type:  defect    |     Status:  new
 Priority:  critical  |  Milestone:  PostGIS 2.3.0
Component:  raster    |    Version:  trunk
 Keywords:            |
 I suspect this is a similar issue to #3502 that something changed in the
 planner in PostgreSQL 9.6 so the order of returned items is not the same
 as it used to be.
  rt_colormap .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_3_pg9.6w64/test_70_diff)
 --- rt_colormap_expected        2015-11-28 06:43:34.770196254 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_3_pg9.6w64/test_70_out
 2016-03-12 20:02:32.996801052 +0000
 @@ -7,30 +7,108 @@
  NOTICE:  Method INTERPOLATE requires at least two non-NODATA colormap
 entries. Using NEAREST instead
 1|1|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
 +1|1|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
 +1|1|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
 +1|1|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
 +1|1|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +1|2|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
 +1|2|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
 1|2|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
 +1|2|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
 +1|2|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +1|3|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
 +1|3|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
 +1|3|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
 +1|3|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +1|4|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
 1|4|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
 +1|4|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
 1|4|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 2|1|{{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255}}
 +2|1|{{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255}}
 +2|1|{{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255}}
 +2|1|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
 2|1|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,130,135,140,145,151},{156,161,166,171,177,182,187,192,198,203},{208,213,218,224,229,234,239,245,250,255}}
 +2|1|{{0,0,5,10,16,21,26,31,36,41},{47,52,57,62,67,73,78,83,88,93},{98,104,109,114,119,124,124,119,114,109},{104,98,93,88,83,78,73,67,62,57},{52,47,41,36,31,26,21,16,10,5},{0,10,21,31,42,52,62,73,83,94},{104,114,125,135,146,156,167,177,187,198},{208,219,229,239,250,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|1|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,132,137,143,148,153,158,164,169,174},{179,184,190,195,200,205,211,216,221,226},{231,237,242,247,252,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|1|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|2|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,130,135,140,145,151},{156,161,166,171,177,182,187,192,198,203},{208,213,218,224,229,234,239,245,250,255}}
 2|2|{{0,0,5,10,16,21,26,31,36,41},{47,52,57,62,67,73,78,83,88,93},{98,104,109,114,119,124,124,119,114,109},{104,98,93,88,83,78,73,67,62,57},{52,47,41,36,31,26,21,16,10,5},{0,10,21,31,42,52,62,73,83,94},{104,114,125,135,146,156,167,177,187,198},{208,219,229,239,250,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|2|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,132,137,143,148,153,158,164,169,174},{179,184,190,195,200,205,211,216,221,226},{231,237,242,247,252,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|2|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|2|{{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255}}
 2|2|{{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255}}
 +2|2|{{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255}}
 +2|2|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
 +2|3|{{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255}}
 +2|3|{{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255}}
 2|3|{{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255}}
 +2|3|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
 +2|3|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,130,135,140,145,151},{156,161,166,171,177,182,187,192,198,203},{208,213,218,224,229,234,239,245,250,255}}
 +2|3|{{0,0,5,10,16,21,26,31,36,41},{47,52,57,62,67,73,78,83,88,93},{98,104,109,114,119,124,124,119,114,109},{104,98,93,88,83,78,73,67,62,57},{52,47,41,36,31,26,21,16,10,5},{0,10,21,31,42,52,62,73,83,94},{104,114,125,135,146,156,167,177,187,198},{208,219,229,239,250,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 2|3|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,132,137,143,148,153,158,164,169,174},{179,184,190,195,200,205,211,216,221,226},{231,237,242,247,252,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|3|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|4|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,130,135,140,145,151},{156,161,166,171,177,182,187,192,198,203},{208,213,218,224,229,234,239,245,250,255}}
 +2|4|{{0,0,5,10,16,21,26,31,36,41},{47,52,57,62,67,73,78,83,88,93},{98,104,109,114,119,124,124,119,114,109},{104,98,93,88,83,78,73,67,62,57},{52,47,41,36,31,26,21,16,10,5},{0,10,21,31,42,52,62,73,83,94},{104,114,125,135,146,156,167,177,187,198},{208,219,229,239,250,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|4|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,132,137,143,148,153,158,164,169,174},{179,184,190,195,200,205,211,216,221,226},{231,237,242,247,252,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 2|4|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +2|4|{{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255}}
 +2|4|{{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255}}
 +2|4|{{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255}}
 2|4|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
 3|1|{{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1}}
 +3|1|{{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127}}
 +3|1|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0}}
 +3|1|{{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +3|2|{{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1}}
 3|2|{{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127}}
 +3|2|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0}}
 +3|2|{{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +3|3|{{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1}}
 +3|3|{{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127}}
 3|3|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0}}
 +3|3|{{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 +3|4|{{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1}}
 +3|4|{{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127}}
 +3|4|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0}}
 3|4|{{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
 4|1|{{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0}}
 +4|1|{{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0}}
 +4|1|{{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255}}
 +4|2|{{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0}}
 4|2|{{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0}}
 +4|2|{{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255}}
 +4|3|{{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0}}
 +4|3|{{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0}}
 4|3|{{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255}}
 5|1|{{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0}}
 The regress I assume probably just needs and ORDER BY in it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3503>
