[postgis-tickets] [PostGIS] #3506: build variable not defined ?
PostGIS trac at osgeo.org
Fri Mar 18 11:12:03 PDT 2016
 Reporter:  darkblueb        |      Owner:  pramsey
     Type:  defect           |     Status:  new
 Priority:  medium           |  Milestone:  PostGIS 2.2.2
Component:  postgis          |    Version:  2.2.x
 Keywords:  autotools, make  |
 something is mysteriously failing in the build -- autotools generated
 environment variables ?  no idea..  This is reproducible (for me) on
 Ubuntu 1404, with PostGIS versions tag 221, and 22branch; It could be
 something about this server, as it is used for other things too !  But the
 bug is that `configure` is not failing, and a spurious error is generated
 later about VERSION.
 `srcs_i7d/postgis_221$ make clean; ./autogen.sh &&  ./configure && make`
 I../libpgcommon postgis.sql.in | grep -v '^#' | \
 /usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.2'g" >
 postgis.sql
 /bin/sh: 1: I../libpgcommon: not found
 /usr/bin/perl ../utils/create_undef.pl postgis.sql 94 >
 uninstall_postgis.sql
 /usr/bin/perl ../utils/postgis_proc_upgrade.pl postgis.sql UNUSED >
 postgis_upgrade.sql.in
 Unable to locate target new version number in postgis.sql
 Makefile:161: recipe for target 'postgis_upgrade.sql.in' failed
 make[1]: *** [postgis_upgrade.sql.in] Error 255
 make[1]: *** Deleting file 'postgis_upgrade.sql.in'
 make[1]: Leaving directory '/home/shared/srcs_i7d/postgis_221/postgis'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3506>
