[postgis-tickets] r14794 - Force sorting in ST_ColorMap test (fix aliasing issue rid was aliased as testid)
Regina Obe lr at pcorp.us
Sun Mar 20 12:52:40 PDT 2016
Author: robe
Date: 2016-03-20 12:52:40 -0700 (Sun, 20 Mar 2016)
New Revision: 14794
   trunk/raster/test/regress/rt_colormap.sql
   trunk/raster/test/regress/rt_colormap_expected
closes #3503
Modified: trunk/raster/test/regress/rt_colormap.sql
--- trunk/raster/test/regress/rt_colormap.sql	2016-03-20 19:41:05 UTC (rev 14793)
+++ trunk/raster/test/regress/rt_colormap.sql	2016-03-20 19:52:40 UTC (rev 14794)
@@ -123,7 +123,7 @@
 SELECT
-	testid
+	testid,
 	rid,
 	(ST_DumpValues(rast)).*
 FROM raster_colormap_out
Modified: trunk/raster/test/regress/rt_colormap_expected
--- trunk/raster/test/regress/rt_colormap_expected	2016-03-20 19:41:05 UTC (rev 14793)
+++ trunk/raster/test/regress/rt_colormap_expected	2016-03-20 19:52:40 UTC (rev 14794)
@@ -6,31 +6,31 @@
 NOTICE:  RGBA value cannot be greater than 255. Defaulting to 255
 NOTICE:  Method INTERPOLATE requires at least two non-NODATA colormap entries. Using NEAREST instead
-1|1|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
-1|1|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
-1|2|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
-1|2|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
-1|3|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
-1|3|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
-1|4|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
-1|4|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
-2|1|{{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255}}
-2|1|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,130,135,140,145,151},{156,161,166,171,177,182,187,192,198,203},{208,213,218,224,229,234,239,245,250,255}}
-2|2|{{0,0,5,10,16,21,26,31,36,41},{47,52,57,62,67,73,78,83,88,93},{98,104,109,114,119,124,124,119,114,109},{104,98,93,88,83,78,73,67,62,57},{52,47,41,36,31,26,21,16,10,5},{0,10,21,31,42,52,62,73,83,94},{104,114,125,135,146,156,167,177,187,198},{208,219,229,239,250,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
-2|2|{{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255}}
-2|3|{{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255}}
-2|3|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,132,137,143,148,153,158,164,169,174},{179,184,190,195,200,205,211,216,221,226},{231,237,242,247,252,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
-2|4|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
-2|4|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
-3|1|{{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1}}
-3|2|{{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127}}
-3|3|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0}}
-3|4|{{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
-4|1|{{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0}}
-4|2|{{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0}}
-4|3|{{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255}}
-5|1|{{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0}}
+1|1|1|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
+1|1|2|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
+1|1|3|{{0,0,3,5,8,10,13,16,18,21},{23,26,29,31,34,36,39,42,44,47},{49,52,55,57,60,62,65,68,70,73},{75,78,81,83,86,88,91,94,96,99},{101,104,107,109,112,114,117,120,122,125},{128,130,133,135,138,141,143,146,148,151},{154,156,159,161,164,167,169,172,174,177},{180,182,185,187,190,193,195,198,200,203},{206,208,211,213,216,219,221,224,226,229},{232,234,237,239,242,245,247,250,252,255}}
+1|1|4|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
+1|2|1|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
+1|2|2|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
+1|2|3|{{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255},{0,0,32,64,96,128,159,191,223,255}}
+1|2|4|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
+2|1|1|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,130,135,140,145,151},{156,161,166,171,177,182,187,192,198,203},{208,213,218,224,229,234,239,245,250,255}}
+2|1|2|{{0,0,5,10,16,21,26,31,36,41},{47,52,57,62,67,73,78,83,88,93},{98,104,109,114,119,124,124,119,114,109},{104,98,93,88,83,78,73,67,62,57},{52,47,41,36,31,26,21,16,10,5},{0,10,21,31,42,52,62,73,83,94},{104,114,125,135,146,156,167,177,187,198},{208,219,229,239,250,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
+2|1|3|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,3,8,13,18},{23,29,34,39,44,49,54,60,65,70},{75,80,86,91,96,101,106,111,117,122},{127,132,137,143,148,153,158,164,169,174},{179,184,190,195,200,205,211,216,221,226},{231,237,242,247,252,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
+2|1|4|{{0,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
+2|2|1|{{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255},{0,0,0,0,64,127,127,127,191,255}}
+2|2|2|{{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255},{0,0,64,127,64,0,128,255,255,255}}
+2|2|3|{{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255},{0,0,0,0,64,127,191,255,255,255}}
+2|2|4|{{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255},{0,255,255,255,255,255,255,255,255,255}}
+3|1|1|{{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1}}
+3|1|2|{{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127}}
+3|1|3|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0}}
+3|1|4|{{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
+3|2|1|{{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1},{1,1,1,1,1,1,1,1,1,1}}
+3|2|2|{{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127},{127,127,127,127,127,127,127,127,127,127}}
+3|2|3|{{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0,0,0}}
+3|2|4|{{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255},{255,255,255,255,255,255,255,255,255,255}}
+4|2|1|{{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0},{255,191,128,64,0,0,0,0,0,0}}
+4|2|2|{{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0},{0,64,128,191,255,255,191,128,64,0}}
+4|2|3|{{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255},{0,0,0,0,0,0,64,128,191,255}}
+5|2|1|{{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0},{255,254,222,191,159,127,95,64,32,0}}
