[postgis-tickets] [PostGIS] #3503: ST_ColorMap regress failing on PostgreSQL 9.6 debbie
PostGIS trac at osgeo.org
Sun Mar 20 17:26:28 PDT 2016
  Reporter:  robe      |      Owner:  dustymugs
      Type:  defect    |     Status:  reopened
  Priority:  critical  |  Milestone:  PostGIS 2.3.0
 Component:  raster    |    Version:  trunk
Resolution:            |   Keywords:
Comment (by robe):
 okay this is not just a sorting issue.  It seem the multiple calls of the
 function triggered by:
         (ST_DumpValues(rast)).*
 is actually creating duplicate records (one for each column). Even though
 people aren't supposed to do that because it does call the function for
 each column output by the (.*), I suspect this was an unintentional change
 in behavior in PostgreSQL 9.6.
 I could just change the tests to pass, but instead I'll complain upstream
 first to confirm they did intend this behavior change.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3503#comment:6>
