[postgis-tickets] r14802 - Links to tickets
Paul Ramsey pramsey at cleverelephant.ca
Tue Mar 22 13:04:24 PDT 2016
Author: pramsey
Date: 2016-03-22 13:04:24 -0700 (Tue, 22 Mar 2016)
New Revision: 14802
   web/_content/posts/2016/03-22_postgis-2.2.2.html
Links to tickets
Modified: web/_content/posts/2016/03-22_postgis-2.2.2.html
--- web/_content/posts/2016/03-22_postgis-2.2.2.html	2016-03-22 19:57:00 UTC (rev 14801)
+++ web/_content/posts/2016/03-22_postgis-2.2.2.html	2016-03-22 20:04:24 UTC (rev 14802)
@@ -11,18 +11,18 @@
 **Bug Fixes and Improvements**
-  * #3463, Fix crash on face-collapsing edge change
-  * #3422, Improve `ST_Split` robustness on standard precision double systems (arm64, ppc64el, s390c, powerpc, ...)
-  * #3427, Update `spatial_ref_sys` to EPSG version 8.8
-  * #3433, `ST_ClusterIntersecting` incorrect for MultiPoints
-  * #3435, `ST_AsX3D` fix rendering of concave geometries
-  * #3436, memory handling mistake in ptarray_clone_deep
-  * #3437, `ST_Intersects` incorrect for MultiPoints
-  * #3461, `ST_GeomFromKML` crashes Postgres when there are innerBoundaryIs and no outerBoundaryIs
-  * #3429, upgrading to 2.3 or from 2.1 can cause loop/hang on some platforms
-  * #3460, `ST_ClusterWithin` "Tolerance not defined" error after upgrade
-  * #3490, Raster [data restore](http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore) issues, materialized views. Added scripts `postgis_proc_set_search_path.sql`, `rtpostgis_proc_set_search_path.sql`
-  * #3426, failing `POINT EMPTY` tests on fun architectures
+  * [#3463](http://trac.osgeo.org/postgis/ticket/3463), Fix crash on face-collapsing edge change
+  * [#3422](http://trac.osgeo.org/postgis/ticket/3422), Improve `ST_Split` robustness on standard precision double systems (arm64, ppc64el, s390c, powerpc, ...)
+  * [#3427](http://trac.osgeo.org/postgis/ticket/3427), Update `spatial_ref_sys` to EPSG version 8.8
+  * [#3433](http://trac.osgeo.org/postgis/ticket/3433), `ST_ClusterIntersecting` incorrect for MultiPoints
+  * [#3435](http://trac.osgeo.org/postgis/ticket/3435), `ST_AsX3D` fix rendering of concave geometries
+  * [#3436](http://trac.osgeo.org/postgis/ticket/3436), memory handling mistake in ptarray_clone_deep
+  * [#3437](http://trac.osgeo.org/postgis/ticket/3437), `ST_Intersects` incorrect for MultiPoints
+  * [#3461](http://trac.osgeo.org/postgis/ticket/3461), `ST_GeomFromKML` crashes Postgres when there are innerBoundaryIs and no outerBoundaryIs
+  * [#3429](http://trac.osgeo.org/postgis/ticket/3429), upgrading to 2.3 or from 2.1 can cause loop/hang on some platforms
+  * [#3460](http://trac.osgeo.org/postgis/ticket/3460), `ST_ClusterWithin` "Tolerance not defined" error after upgrade
+  * [#3490](http://trac.osgeo.org/postgis/ticket/3490), Raster [data restore](http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore) issues, materialized views. Added scripts `postgis_proc_set_search_path.sql`, `rtpostgis_proc_set_search_path.sql`
+  * [#3426](http://trac.osgeo.org/postgis/ticket/3426), failing `POINT EMPTY` tests on fun architectures
 See the full list of changes in the [news file](http://svn.osgeo.org/postgis/tags/2.2.2/NEWS) and please [report bugs](https://trac.osgeo.org/postgis) that you find in the release.
