[postgis-tickets] [PostGIS] #3485: ST_ClusterKMeans garden crash - not empty geometry safe
PostGIS trac at osgeo.org
Sat Mar 26 14:05:21 PDT 2016
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by pramsey):
 Confirm it's still there for you? I did some changes in this area of
 problem and I'm not seeing it against turnk
 p=# SELECT ST_ClusterKMeans(foo1.the_geom, 1)OVER()  As result
 p-# FROM (SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom) As foo1;
 ERROR:  unable to calculate cluster seed points, too many NULLs or
 empties?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3485#comment:4>
