[postgis-tickets] [PostGIS] #3517: HTTP 403 Forbidden at http://postgis.net/casestudy/
PostGIS trac at osgeo.org
Wed Mar 30 00:15:13 PDT 2016
  Reporter:  dbaston  |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  Management 2.0
 Component:  website  |    Version:  2.2.x
Resolution:           |   Keywords:
Comment (by robe):
 It works fine for me.
 I think the issue might be intermittent.  You see the svn updates every 5
 minutes and there is something fishy about our piecrust setup.  So to work
 around the issue, I have to purge the counter file and rebuild twice.
 While it's rebuilding the counter folder, you get that silly error.  I
 haven't found a fix for that.  We might want to go with strk's svn pull
 thingy so that it only does a build if there is something worth building.
 Alternatively if someone is smart enough to fiddle with the shell script
 so it detects when there is an svn update and wrap the rebaking in that
 that would resolve this issue.
 Come to think of it, I think this may be the cause of pramsey's complaint
 about getting 404 on Planet PostgreSQL - because it probably registers a
 404 while building.
 Anywhoo I have the whole nasty issue logged in #3387 and my half-assed
 work-around for it. Let me know if there is anything you think I should
 change in the script.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3517#comment:3>
