[postgis-tickets] [PostGIS] #3659: Crash with MinGW64
PostGIS trac at osgeo.org
Mon Oct 10 00:24:56 PDT 2016
 Reporter:  manaeem  |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.3.1
Component:  postgis  |    Version:  2.3.x
 Keywords:           |
 I am using PostGIS 2.2.3
 (http://download.osgeo.org/postgis/source/postgis-2.2.3.tar.gz) with
 MinGW64, It is failing with "0xC0000005: Access violation reading location
 0x0000000029C6AD70" exception.
 test=# create extension postgis;
 CREATE EXTENSION
 test=# select * from pg_settings;
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 The connection to the server was lost. Attempting reset: Failed.
 >? values
 0x000000000042cf20 {0x0000000028c80af0 "postgis.gdal_enabled_drivers",
 0x0000000029b7bee0 "DISABLE_ALL", ...}
     [0]: 0x0000000028c80af0 "postgis.gdal_enabled_drivers"
     [1]: 0x0000000029b7bee0 "DISABLE_ALL"
     [2]: 0x0000000000000000 <NULL>
     [3]: 0x00000001405ae0b8 "Customized Options"
     [4]: 0x000000006b806221 "Enabled GDAL drivers."
     [5]: 0x000000006b806190 "List of enabled GDAL drivers by short name.
 To enable/disable all drivers, use 'ENABLE_ALL' or 'DISABLE_ALL' (sets the
 GDAL_SKIP config option)."
     [6]: 0x000000014048d660 "superuser"
     [7]: 0x0000000140551274 "string"
     [8]: 0x0000000140492ce8 "default"
     [9]: 0x0000000000000000 <NULL>
     [10]: 0x0000000000000000 <NULL>
     [11]: 0x0000000000000000 <NULL>
     [12]: 0x0000000000000000 <NULL>
     [13]: 0x00000000008a21a0 ""
     [14]: 0x0000000000000000 <NULL>
     [15]: 0x0000000000000000 <NULL>
     [16]: 0x00000000008a21a0 ""
 Issue seems reproducible in PostGIS version 2.3 and 2.4 as well. backend
 process is crashing while processing bootValue define done by PostGIS
 extension i.e.
 raster/rt_pg/rtpostgis.c
         DefineCustomStringVariable(
                 "postgis.gdal_enabled_drivers", /* name */
                 "Enabled GDAL drivers.", /* short_desc */
                 "List of enabled GDAL drivers by short name. To
 GDAL_SKIP config option).", /* long_desc */
                 &gdal_enabled_drivers, /* valueAddr */
                 boot_postgis_gdal_enabled_drivers, /* bootValue */
                 PGC_SUSET, /* GucContext context */
                 0, /* int flags */
 #if POSTGIS_PGSQL_VERSION >= 91
                 NULL, /* GucStringCheckHook check_hook */
 #endif
                 rtpg_assignHookGDALEnabledDrivers, /* GucStringAssignHook
 assign_hook */
                 NULL  /* GucShowHook show_hook */
 boot_postgis_gdal_enabled_drivers is allocated on CurrentMemoryContext via
 palloc() in related extension initialization routine (_PG_init), instead
 it is appropriate to utilize TopMemoryContext instead. PFA patch with it,
 crash is no more reproducible with it. Thanks.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3659>
