[postgis-tickets] [PostGIS] #3635: utils/create_spatial_ref_sys_config_dump.pl has hardcoded perl path
PostGIS trac at osgeo.org
Tue Sep 20 01:30:03 PDT 2016
  Reporter:  gdt                    |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 Note that postgis_upgrade.pl is generated at ./configure time from
 postgis_upgrade.pl.in, if you're looking for an example
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3635#comment:1>
