[postgis-tickets] [PostGIS] #3737: Upgrading from 2.2.5 to 2.3.2 problem
PostGIS trac at osgeo.org
Wed Apr 12 08:11:09 PDT 2017
  Reporter:  zeddi                  |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.3.3
 Component:  build/upgrade/install  |    Version:  2.3.x
Resolution:                         |   Keywords:
Comment (by robe):
 I suspect your postgis.control file might be the old one from PostGIS 2.2
 and didn't get the 2.3 installed.  In PostGIS 2.3 the schema is no longer
 relocatable.  When not relocateable the @extchema@ gets macroreplaced by
 the extension machinery to the schema choosen by the user.
 Your postgis.control should have:
 relocatable = false
 otherwise the extension system will not resolve the @extschema@ variables.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3737#comment:7>
