[postgis-tickets] [PostGIS] #3739: ST_Within Not using index
PostGIS trac at osgeo.org
Mon Apr 17 04:46:30 PDT 2017
  Reporter:  postgispaul  |      Owner:  pramsey
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.3.3
 Component:  postgis      |    Version:  2.3.x
Resolution:               |   Keywords:
Comment (by postgispaul):
 Thanks for your reformatting and fast answer!
 St_intersects does not have that issue. It's correctly using the index on
 ap.way && s.way without explicitly adding that condition.
 I also did create a new
  CREATE OR REPLACE FUNCTION public.st_withintest(
     geom1 geometry,
     geom2 geometry)
   RETURNS boolean AS
 'SELECT $2 OPERATOR(public.~) $1 AND public._ST_Contains($2,$1)'
   LANGUAGE sql IMMUTABLE
   COST 100;
  function to rule out messed up function definitions, but that didn't help
 either.
 Could that corrupt index be caused by postgres 9.6.1? I did see some
 related bugs fixed in 9.6.3
 Anyway, reindex is running
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3739#comment:3>
