[postgis-tickets] [PostGIS] #3738: Using -s and -R together in raster2pgsql transforms raster data instead of setting srid
PostGIS trac at osgeo.org
Tue Apr 18 06:57:34 PDT 2017
setting srid
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 2.4.0
 Component:  raster  |    Version:  2.3.x
Resolution:          |   Keywords:
Changes (by robe):
 * owner:  dustymugs => robe
Old description:
> I haven't tested this myself, but on postgis users list, two people
> mentioned this behavior:
> https://lists.osgeo.org/pipermail/postgis-users/2017-April/042020.html
> 2017-04-11 14:25 GMT+02:00 Tumasgiu Rossini <rossini.t at gmail.com>:
> > Hi,
> > I think I found the probelm, it is the -s option which make the sql
> > applying a st_transfrom on the raster to reproject it into the desired
> CRS
> > before inserting it in the table, thus creating an in-db raster.
New description:
 > Hi,
 CRS
 As Pierre noted, best thing to do is use the same reprojection syntax and
 shp2pgsql -s from_srid:to_srid  (this might work already) have to test.
 and forbit transform with out-db.  Since there is no point if its going to
 end up being in-db.
 https://lists.osgeo.org/pipermail/postgis-users/2017-April/042050.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3738#comment:2>
