[postgis-tickets] r15354 - Clear hash tables after usage
bjorn at wololo.org bjorn at wololo.org
Wed Apr 19 10:43:19 PDT 2017
Author: bjornharrtell
Date: 2017-04-19 10:43:18 -0700 (Wed, 19 Apr 2017)
New Revision: 15354
   trunk/postgis/mvt.c
   trunk/postgis/mvt.h
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2017-04-12 13:36:21 UTC (rev 15353)
+++ trunk/postgis/mvt.c	2017-04-19 17:43:18 UTC (rev 15354)
@@ -190,7 +190,7 @@
 		c += 2 + lwmline->geoms[i]->points->npoints * 2;
 	feature->geometry = palloc(sizeof(*feature->geometry) * c);
 	for (i = 0; i < lwmline->ngeoms; i++)
-		offset += encode_ptarray(ctx, MVT_LINE,
+		offset += encode_ptarray(ctx, MVT_LINE,
 			lwmline->geoms[i]->points,
 			feature->geometry + offset, &px, &py);
 	feature->n_geometry = offset;
@@ -328,6 +328,13 @@
 	ctx->layer->n_values = ctx->values_hash_i;
 	ctx->layer->values = values;
+	HASH_CLEAR(hh, ctx->string_values_hash);
+	HASH_CLEAR(hh, ctx->float_values_hash);
+	HASH_CLEAR(hh, ctx->double_values_hash);
+	HASH_CLEAR(hh, ctx->uint_values_hash);
+	HASH_CLEAR(hh, ctx->sint_values_hash);
+	HASH_CLEAR(hh, ctx->bool_values_hash);
 #define MVT_PARSE_VALUE(value, kvtype, hash, valuefield, size) \
@@ -463,7 +470,7 @@
  * Makes best effort to keep validity. Might collapse geometry into lower
  * dimension.
-LWGEOM *mvt_geom(LWGEOM *lwgeom, GBOX *gbox, uint32_t extent, uint32_t buffer,
+LWGEOM *mvt_geom(LWGEOM *lwgeom, GBOX *gbox, uint32_t extent, uint32_t buffer,
 	bool clip_geom)
 	double width = gbox->xmax - gbox->xmin;
@@ -533,7 +540,7 @@
  * Initialize aggregation context.
-void mvt_agg_init_context(struct mvt_agg_context *ctx)
+void mvt_agg_init_context(struct mvt_agg_context *ctx)
 	VectorTile__Tile__Layer *layer;
@@ -544,7 +551,6 @@
 	ctx->string_values_hash = NULL;
 	ctx->float_values_hash = NULL;
 	ctx->double_values_hash = NULL;
-	ctx->int_values_hash = NULL;
 	ctx->uint_values_hash = NULL;
 	ctx->sint_values_hash = NULL;
 	ctx->bool_values_hash = NULL;
@@ -628,4 +634,4 @@
 	return buf;
-#endif
\ No newline at end of file
+#endif
Modified: trunk/postgis/mvt.h
--- trunk/postgis/mvt.h	2017-04-12 13:36:21 UTC (rev 15353)
+++ trunk/postgis/mvt.h	2017-04-19 17:43:18 UTC (rev 15354)
@@ -31,7 +31,7 @@
 #include "utils/array.h"
 #include "utils/typcache.h"
 #include "utils/lsyscache.h"
-#include "catalog/pg_type.h"
+#include "catalog/pg_type.h"
 #include "executor/executor.h"
 #include "access/htup_details.h"
 #include "access/htup.h"
@@ -57,7 +57,6 @@
 	struct mvt_kv_string_value *string_values_hash;
 	struct mvt_kv_float_value *float_values_hash;
 	struct mvt_kv_double_value *double_values_hash;
-	struct mvt_kv_int_value *int_values_hash;
 	struct mvt_kv_uint_value *uint_values_hash;
 	struct mvt_kv_sint_value *sint_values_hash;
 	struct mvt_kv_bool_value *bool_values_hash;
@@ -72,4 +71,4 @@
 #endif  /* HAVE_LIBPROTOBUF */
-#endif
+#endif
