[postgis-tickets] [PostGIS] #3738: raster: Using -s and -R together in raster2pgsql transforms raster data instead of setting srid
PostGIS trac at osgeo.org
Sun Apr 23 10:12:01 PDT 2017
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 2.4.0
 Component:  raster  |    Version:  2.3.x
Resolution:          |   Keywords:
Comment (by robe):
 quick scan of raster2pgsql
 http://postgis.net/docs/doxygen/2.4/db/dd0/raster2pgsql_8c_source.html,
 looks like we already support the -s srid_from:srid_to syntax for
 transformation.
 2312                 if (CSEQUAL(argv[i], "-s") && i < argc - 1) {
  2313                         optarg = argv[++i];
  2314                         ptr = strchr(optarg, ':');
  2315                         if (ptr) {
  2316                                 *ptr++ = '\0';
  2317                                 sscanf(optarg, "%d", &config->srid);
  2318                                 sscanf(ptr, "%d",
 &config->out_srid);
  2319                         } else {
  2320                                 config->srid = config->out_srid =
 atoi(optarg);
  2321                         }
  2322                 }
 Thought haven't verified it works and the documentation of it is commented
 out:
   333         printf(_(
   334                 "  -s [<from>:]<srid> Set the SRID field. Defaults
 to %d.\n"
   335                 "     Optionally reprojects from given SRID (cannot
 be used with -Y).\n"
   336                 "     Raster's metadata will be checked to determine
 an appropriate SRID.\n"
   337                 "     If a srid of %d is provided (either as from or
 as target).\n"
   338         ), SRID_UNKNOWN, SRID_UNKNOWN);
   339         */
   340         printf(_(
   341                 "  -s <srid> Set the SRID field. Defaults to %d. If
 SRID not\n"
   342                 "     provided or is %d, raster's metadata will be
 checked to\n"
   343                 "     determine an appropriate SRID.\n"
   344         ), SRID_UNKNOWN, SRID_UNKNOWN);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3738#comment:4>
