[postgis-tickets] r15363 - ST_Subdivide loses subparts of inverted geometries patch from Darafei Praliaskouski (Komzpa)
Regina Obe lr at pcorp.us
Mon Apr 24 11:01:43 PDT 2017
Author: robe
Date: 2017-04-24 11:01:43 -0700 (Mon, 24 Apr 2017)
New Revision: 15363
   trunk/liblwgeom/lwgeom.c
   trunk/regress/subdivide.sql
   trunk/regress/subdivide_expected
References #3744
changed area regress to cast to numeric so doesn't return scientific notation on windows
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c	2017-04-23 20:34:18 UTC (rev 15362)
+++ trunk/liblwgeom/lwgeom.c	2017-04-24 18:01:43 UTC (rev 15363)
@@ -1979,11 +1979,11 @@
 		return n;
-	/* But don't go too far. 2^25 = 33M, that's enough subdivision */
-	/* Signal callers above that we depth'ed out with a negative */
-	/* return value */
+	/* But don't go too far. 2^50 ~= 10^15, that's enough subdivision */
+	/* Just add what's left */
 	if ( depth > maxdepth )
+		lwcollection_add_lwgeom(col, lwgeom_clone_deep(geom));
 		return 0;
@@ -2030,15 +2030,17 @@
 	clipped1 = lwgeom_clip_by_rect(geom, subbox1.xmin, subbox1.ymin, subbox1.xmax, subbox1.ymax);
 	clipped2 = lwgeom_clip_by_rect(geom, subbox2.xmin, subbox2.ymin, subbox2.xmax, subbox2.ymax);
+	++depth;
 	if ( clipped1 )
-		n += lwgeom_subdivide_recursive(clipped1, maxvertices, ++depth, col, &subbox1);
+		n += lwgeom_subdivide_recursive(clipped1, maxvertices, depth, col, &subbox1);
 		lwgeom_free(clipped1);
 	if ( clipped2 )
-		n += lwgeom_subdivide_recursive(clipped2, maxvertices, ++depth, col, &subbox2);
+		n += lwgeom_subdivide_recursive(clipped2, maxvertices, depth, col, &subbox2);
 		lwgeom_free(clipped2);
Modified: trunk/regress/subdivide.sql
--- trunk/regress/subdivide.sql	2017-04-23 20:34:18 UTC (rev 15362)
+++ trunk/regress/subdivide.sql	2017-04-24 18:01:43 UTC (rev 15363)
@@ -24,3 +24,20 @@
 GROUP BY gs.full_area;
 SELECT '#3522', ST_AsText(ST_Subdivide(ST_GeomFromText('POINT(1 1)',4326),10));
+with inverted_geom as (
+    select ST_Difference(
+               ST_Expand('SRID=3857;POINT(0 0)' :: geometry, 20000000),
+               ST_Buffer(
+                   'SRID=3857;POINT(0 0)' :: geometry,
+                   1,
+                   1000
+           ) as geom
+select 'https://github.com/postgis/postgis/pull/127', ST_Area(ST_Simplify(ST_Union(geom), 2))::numeric
+from (
+         select ST_Subdivide(geom) geom
+         from inverted_geom
+     ) z;
Modified: trunk/regress/subdivide_expected
--- trunk/regress/subdivide_expected	2017-04-23 20:34:18 UTC (rev 15362)
+++ trunk/regress/subdivide_expected	2017-04-24 18:01:43 UTC (rev 15363)
@@ -2,3 +2,4 @@
 2|t|6|7
 3|t|15|9
 #3522|POINT(1 1)
+https://github.com/postgis/postgis/pull/127|1600000000000000
