[postgis-tickets] [PostGIS] #3742: mvt regress failure on debbie and winnie
PostGIS trac at osgeo.org
Tue Apr 25 01:13:18 PDT 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by Björn Harrtell):
 When I run the TA8 test case manually in pgadmin I get:
 "GkEKBHRlc3QSDBICAAAYASIECTLePxIMEgIAABgBIgQJNNw/EgwSAgABGAEiBAk03D8aAmMxIgIo
 ASICKAIogCB4Ag==" (which is the correct encoding)
 When I run the test case using run_test.pl or make check I get:
 "GkUKBHRlc3QSDBICAAAYASIECTLePxIMEgIAARgBIgQJNNw/EgwSAgACGAEiBAk03D8aAmMxIgIo
 ASICKAEiAigCKIAgeAI=" (which is the incorrect encoding)
 It does not matter if I reorder the tests so that it tries this case
 before any other.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3742#comment:13>
