[postgis-tickets] r15373 - Revert committ of astyle and commit the intended textstyle.sty
Regina Obe lr at pcorp.us
Tue Apr 25 20:39:42 PDT 2017
Author: robe
Date: 2017-04-25 20:39:41 -0700 (Tue, 25 Apr 2017)
New Revision: 15373
Added:
   trunk/doc/texstyle.sty
Removed:
   trunk/astyle
References #3726 for PostGIS 2.4 trunk
Deleted: trunk/astyle
--- trunk/astyle	2017-04-25 21:39:58 UTC (rev 15372)
+++ trunk/astyle	2017-04-26 03:39:41 UTC (rev 15373)
@@ -1,27 +0,0 @@
-#!/bin/bash
-# Run astyle on the code base ready for release
-# If astyle doesn't exist, exit the script and do nothing
-which astyle > /dev/null
-RET=$?
-if [ $RET -ne 0 ]; then
-	echo "Could not find astyle - aborting."
-	exit
-fi
-RET=`astyle --version 2>&1`
-if [ "$RET" != "Artistic Style Version 1.23" ]; then
-	echo "Only 1.23 astyle version is 'allowed'"
-	exit
-fi
-# Find all "pure" C files in the codebase
-#   - not .in.c used for .sql generation
-#   - not lex.yy.c or wktparse.tab.c as these are generated files
-CFILES=`find . -name '*.c' -not \( -name '*_parse.c' -o -name '*_lex.c' \)`
-# Run the standard format on the files, and do not
-# leave .orig files around for altered files.
-astyle --style=ansi --indent=tab --suffix=none $CFILES
Added: trunk/doc/texstyle.sty
--- trunk/doc/texstyle.sty	                        (rev 0)
+++ trunk/doc/texstyle.sty	2017-04-26 03:39:41 UTC (rev 15373)
@@ -0,0 +1,14 @@
+%% This style is derived from the manual
+%% http://dblatex.sourceforge.net/doc/manual/sec-custom-latex.html
+\NeedsTeXFormat{LaTeX2e}
+\ProvidesPackage{texstyle}[2017/04/25 PostGIS DocBook Style]
+%% Just use the original package and pass the options
+\RequirePackageWithOptions{docbook}
+%% Make regular quotes within programlisting tags (#3726)
+\usepackage{listings}
+\lstset{upquote=true}
